Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
Sim card inserted without tray
Hi,
Does anyone have experience removing a SIM card that was inserted without a tray? The tray was lost and the owner was desperate for the phone to work so she inserted the SIM without the tray. Surprisingly the phone works, but we want to change the SIM card.
Thanks,
David
Esta é uma boa pergunta?
Pontuação 4
3 comentários
I ordered a new SIM card tray from fixit. The SIM card was removed with tweezers. The SIM card was reinstalled with the tray and everything works now. Thanks.
por
Glad to help.
por
I came up with using multiple layers of scotch tape and cut it to appear like what you see when you take a cell phone apart and we're dealing with these ribbons; I created a tail so I can pull the sim card from the slot.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Try to dig it out with a straight pin or a paper clip with the phone powered off, I have been successful doing it that way, if you are unsuccessful then the motherboard will need to be removed and then its easily removed from the underside of the board, good luck, iPhone 4 Logic Board Replacement
Esta resposta foi útil?
Pontuação 1
How did they get the sim in without the tray?
Pontuação 0
1 comentário:
plz can anyone can tell me how to insert sim in iphone 5 without sim tray plz im suffering a reply would be helpful . tahashaikh536@gmail.com
por
Adicionar a sua resposta
David Strom será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 14
Ao todo: 27,005
