Ir para o conteúdo principal
two 2.5" drives INSTEAD of one 3.5" HD (apple fusion drive)
Hi Guys
Maybe I´m being stupid here so I thought you could help me out:
I want to get more mileage out of my iMac 21" 2010 and when I heard about fusion drive ( http://www.anandtech.com/show/6406/under... ) it hit me:
Pull the 500GB 3,5" HD and swap it for a 2*2.5"to 3.5" adapter tray (like this one http://www.newegg.com/Product/Product.as... ) and install a 1TB 2.5 HD plus a 128GB or 256GB SSD in its place.
Obviously I´d need a SATA Y-cable to connect two drives to the motherboard (or is there a spare SATA connector?)
Anybody tried this before?
Any practical theoretical roadblocks?
Would love to get your input.
cheers
Matt
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi matt,
The bad news is there is no such thing as a SATA splitter data cable—the interface doesn't support stringing multiple drives on a single channel.
The qualified good news is that there is a second SATA port on your logic board, but it's being used for the optical drive.
The only way to get a second drive in there will be to replace the optical drive, like in our dual hard drive kit guide.
Hope this helps, good luck fixing.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
matt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 1,549
