Ir para o conteúdo principal
Guias de reparo e informações de desmontagem de telefones de todos os fabricantes e provedores de serviços, incluindo o iPhone da Apple e o Samsung Galaxy. Tenha tudo o que você precisa para reparar o seu telefone por conta própria.
73638 Perguntas Visualizar todos
Solder type to use on cell phones
Im looking on working on some charge ports for many cell phones and was wondering what would be a good soldering wire to use on cell phone pcb's, Size, Ratio and lead or lead-free. Any suggestions would be appreciated. Thanks
Esta é uma boa pergunta?
Pontuação 1
2 comentários
What wou8l;d be a good flux and acid free or acid flux
por
i know this post is old, but im getting into doing some deep hardware editing… like using an s8’s board and connecting it to a different external touchscreen, and inserting the hardware into a new handmade case. This was the result of my first search. thank you guys for assuring me things like this are possible
por
Adicionar um comentário
2 respostas
Solução escolhida
Most, if not all devices are now assembled using lead free solder as it is a requirement to be in the European market (ROHS) I would suggest using something like 1mm Lead Free Solder
Imagem de Lead-Free Solder
Produto
Lead-Free Solder
Esta resposta foi útil?
Pontuação 2
I use 63/37 lead solder to repair most smd components. I use 62/36/2 to solder charge ports. I always use a good quality flux it can make a world of difference in the solder quality.
Pontuação 1
2 comentários:
Craig do you have an email? I have some questions.
por
Craig you mentioned using a specific solder and flux. Can you provide the product info for both. I need to repair a Samsung Tab 3 7.0 charge port that requires soldering.
por
Adicionar a sua resposta
retlaw23559 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 32
Duração total: 13,350
