Ir para o conteúdo principal
How can I fix this?
My Ipod touch 4th gen. screen was broken and I repaired it. Now when I try to turn it on, a white screen shows up.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
make sure all the connectors are connected and try doing a iTunes restore
Esta resposta foi útil?
Pontuação 0
do you sure the konectore scren put correctly? make sure the screen type corect too
Pontuação 0
If the LCD connectors are properly connected then try resetting your device by pressing and holding home and power button until the screen goes black and turns on again. If this thing doesn't help then you may need to go for LCD replacement.
Pontuação 0
1 comentário:
Did you bother to look at the date the question was asked? I doubt bakerkylee still has a problem here.
por
Adicionar a sua resposta
bakerkylee será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 227
