Ir para o conteúdo principal
Pergunta encerrada
Dark display, no keyboard and display backlight
MacBook Pro 15" Core 2 Duo Model A1226
Hi guys,
I tried everything I could do, but nothing helped.
- Changed the LED Driver Board - no success.
- Changed the LED Display - no success.
- Changed the whole Display as a unique part - no success.
It's definitely not a graphic card issue, because I'm able to use an external display, and everything seems to be fine.
Can someone help me to get my MBP work again?
Thanks.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
I heard something about a "fuse". Could someone explain more about it? Thanks.
por
Adicionar um comentário
3 respostas
have you tried to reset SMC and PRAM?
Esta resposta foi útil?
Pontuação 0
1 comentário:
Yes I tried, but nothing happened...
por
Keyboard backlight is working now, but my display is still dark -.-
ANY idea?
Pontuação 0
i had the same issue. i had tried to reset smc and pram, disconnect and connect again the video cable cleared and removed dust from internal of case but i had kb and display dark...please help...in a assistance center he had referred me the it was a logic board issue but i listen a statup chime...for me HW was ok.
Pontuação 0
1 comentário:
I didn't get it! What was the solution?
por
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 851
