Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Pergunta encerrada
changed cracked digitizer/lcd and now iPhone wont say insert SIM card
I recently changed the lcd for my iphone 4s. Before the change I tested it out and it would say insert sim (no sim included, purchased from ebay). I installed and now it just shows 'searching' and no longer asks to insert a sim card, even when there is not one inserted. I took it apart again and checked all connections. So right now it will not activate at all.
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
is it the ios 6 bug? check if the time and date are set right
por
Time is set correctly. I can not see the date due to not being able to go past the activation screen.
por
check you battery connector, maybe one of the 4 solderpoints are damaged.
por
Adicionar um comentário
1 resposta
Just had the same issue , hooked it up to my macbook and it automatic changed the time and date, then turned it off and on again, .. Fine !
Thanks
Esta resposta foi útil?
Pontuação 0
1 comentário:
Yeah I tried itunes, but it just says can not activate.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 689
