Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Perguntas Visualizar todos
How dow I get it to turn on if it won't charge?
My iphone 3g won't turn on it has the sleep button and home button not working. and it worked fine until it ran out of battery. then i plugged it in and it showed the charging sign, I left it there for 40 minutes and it was still there. after that i unplugged it and tried a different power source and nothing showed up. i tried leaving it charging over night and still nothing.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
you will have to change the battery
iPhone 3G Battery Replacement
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Xavier será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 335
