Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Middle frame insulating adhesive film: necessary?
I'm about to replace a middle frame of an iPhone 4S.
The one I ordered came without the adhesive film that should prevent contact with the LCD
Do I really need that? What is it for? Can I put another kind of sticker or simply nothing?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
I dont know how important is but i found this info about heat shield:
"There is disclosed a liquid crystal display (LCD) device that prevents degeneration of a displaying performance due to heat generated in the LCD. A heat shielding thin film of an aluminum-contained material, which is disposed in a receiving container, shields the heat additionally generated during a converting process of power for driving a lamp in an inverter module, thereby minimizing the heat to be transferred to a reflector panel. Therefore, the heat generated during a process of producing light is efficiently blocked and discharged, thereby minimizing the degeneration of displaying characteristic"
I have changed many middle frames for iphone 4 and there was not any problems.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Jacopo Scarpellini será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 850
