Ir para o conteúdo principal
grey wire broken at batterie connector
Repairing my MacBookPro (end of 2006) a light grey wire broke, which is soldered to the connector for the batterie.
Guess the soldering on that white connector is so fine, that I can not fix this with a "normal manual" soldering job.
The machine works fine.
What purpose has this light grey wire?
What hardware function do I loose?
What can go wrong with my MacBookPro?
Can the entire connector with the wires be replaced?
(Would like to attach a picture, guess this is not possible)
Update
Thanks for the help to everybody.
The case can be closed.
As the Mac works with this wire broken/disconnected....
....so I do not know what hardware function do I really loose.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
It is a power wire - you can probably find a replacement cable from a parts supplier or from a similar model MBP with other issues (broken display for example). There is even a guide for how to safely remove the connector.
If this answer was helpful please remember to mark it accepted.''
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
paul será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 653
