Ir para o conteúdo principal
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
20 Perguntas Visualizar todos
Laptop not turning On when pressing power Button
When I press on Power Button only the media player touch LED blinks once and the light for caps and numlock continuously blinks even I can see power on DVDROM and fan too moves . But none of the LED in front blinks and no power on monitor is there.
Could you please suggest me what should I do.
Esta é uma boa pergunta?
Pontuação 2
2 comentários
can you attach an external monitor and see if you get anything? Any post beep's?
por
Use this : Dell AC Adapter LA90PM130
por
Adicionar um comentário
2 respostas
Solução escolhida
Thanks for your Suggestion "oldturkey03"
I have troubleshooted it and found the reason, its because one of my RAM has gone Bad.
Regards,
Amit Lal
Esta resposta foi útil?
Pontuação 0
Some times the Heat sink & fan gets dust and due to which system gets heated.
Once cleaned can help overheating & abnormal switching off issue.
Pontuação 0
Adicionar a sua resposta
Amit Lal será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 11
Duração total: 4,028
