Loose Battery Terminal causing apple logo boot loop?
Hi
I did some repairs on my i4 the other day and when I removed the battery, the battery terminal lifted up from the board (although it still looks attached to the 4 solder points)
The battery was also faulty so I have removed it, Now when I try to power the phone from mains it turns on properly and shows the 'Connect to iTunes' screen, however when powering through USB the apple logo comes on for a few seconds before restarting and looping.
Is this due to the battery terminal coming loose? if so do I need to just redo the soldering for the 4 pins? or do the 2 circular pins under the terminal do anything apart from hold the terminal to the board?
Thanks
J
Esta é uma boa pergunta?
1 comentário
i also have this problem on my iphone 5s. Same thing happened. i dropped it and now it wont turn on. i tried to research about it and tried to do the itunes thing. however when i started the recovery it says something like error. i also tried putting a book over it and applied pressure because i saw a video about putting pressure helps put the battery or the connector back in place. are there any alternatives other than prying it open?
por hannah
