Ir para o conteúdo principal
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Perguntas Visualizar todos
New battery only charges to 52%
I bought a replacement battery for my macbook pro (mid 2009 15 in.,2.66ghz) after replacing the battery it will only charge to 52%. I reset the pram and the smu ,but I get the same result. Hardware readout and coconut say the battery is fine, but I did notice that the amperage from the macs power readout for the battery is negative.
Any ideas what could be wrong, or is it just a defective battery?
Esta é uma boa pergunta?
Pontuação -1
2 comentários
By new, do you mean, brand new or second hand new? You can use this app to diagnose your battery. http://www.coconut-flavour.com/coconutba...
por
The battery is new from DV Wharehouse. I used the Coconut app and the battery seems fine.
por
Adicionar um comentário
1 resposta
Solução escolhida
I have seen new Chinese batteries fail straight out of the box... you should contact the vendor about this.
If this answer was helpful please remember to return and mark it Accepted.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
nsolo100 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 639
