Ir para o conteúdo principal
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Perguntas Visualizar todos
Accidentally broke off the one of the digitizer flex contacts tabs
Accidentally broke off one of the digitizer flex contacts black flip up tabs that holds the digitizers flex cable down, and now half of the digitizer/screen response is a dead spot how can I fix that little black tab that holds down the digitizer flex cable? I really hope I don't have to replace the whole logic board just because of one small tab. I tried looking for answers and couldn't' find anything and tried looking for maybe replacement parts or a replacement logic board but it seems like no one sells new 16GB iPad 2 Wifi logic board. It would be greatly appreciated if I could get some help.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
I had that happen before. Usually pretty bad sign, I am not aware of a replacement part. The only advice I can give you (besides ask someone who has more experience with this specific problem) is to seat it very carefully and not more it when closing, maybe try some tape or adhesive (not liquid, it will likely get between the contacts). Hope this helps
Esta resposta foi útil?
Pontuação 0
I did the same thing. Ended up sending my board to http://www.servdigital.com/. They replaced both connectors and it works great. Fast service. I had a 64gb ipad so the cost was worth it.
Pontuação 0
Try putting a thin piece of plastic on top of the flex cable as you slide it in. This will provide more downward pressure. Although I have never used this technique for ipad I have successfully used this on PS3 drive flex cables and keyboard cables in laptops. The trick is to find a thin hard plastic and then cut it to the exact width of the flex cable.
Good luck!
Pontuação 0
Adicionar a sua resposta
Michael Sessions será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 1,213
