Ir para o conteúdo principal
Model A1019 / 10 or 20 GB hard drive / full-size Firewire port
New Battery Won't Charge
I just replaced the battery for my second generation iPod purchased from Ifixit and using the excellent procedures.
The battery I recieved was fully charged and my iPod worked just fine; however the battery ran down and the iPod will not charge it from either the USB port on my PC or from the 110vac outlet.
Any suggestions; perhaps a bad battery?
Thanks,
Sam Ske
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Well, if this is really a second generation iPod, it's not going to charge from USB. It has a FireWire port on the top- thus no USB capability. You'll need to charge it with a FireWire cable and FireWire charger.
Esta resposta foi útil?
Pontuação 0
2 comentários:
I have two cables, each used to work.
1) USB to iPod
2) Transformer (110 vac) with fire wire interface to iPod
Neither solution works including PC-Fire wire-iPod.
por
I'm pretty sure there's no way to use USB with the first or second generation iPod. Do you have the iPod listed on the sidebar?
por
Adicionar a sua resposta
samske1 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 1,326
