Why won't it start?
My fa50 won't start. It gets good spark,gas,air,and air compression. Why won't it start?
Esta é uma boa pergunta?
the main jet needs to be cleaned in the carb .. take off the carb and clean it out
Esta resposta foi útil?
Sounds as if you are not getting fuel from the carburator into the cylinder correctly, if it were me, I would remove and then clean that carburator by use of some instructions from a repair manual.
Últimas 24 horas: 7
Últimos 7 dias: 11
Últimos 30 dias: 29
Ao todo: 3,330
4 comentários
What have you tried so far? Tried to squirt a bit of gas into the spark plug hole and try to start it, just to make sure it does get fuel?
por oldturkey03
yes but dies once gas burnt
por jwhiteboy68
jwhiteboy68, is this the same moped? Are you rodneylambert45? Just making sure we are dealing with the same issue here.
por oldturkey03
Here to, won't start normal ,does wel with startpilot at airfilter. When warm motor ,starts fine with kick only.
por Noel De Wulf
