Ir para o conteúdo principal
Repair guides for the MacBook.
3786 Perguntas Visualizar todos
NO SOUND OUTPUT. Help
I have been in the sound settings but I cant ajust the sound as it is not highlited. The message in the box says; THE SELECTED DEVICE HAS NO OUTPUT CONTROLS.
How can I activate?
Many thanks
Esta é uma boa pergunta?
Pontuação -1
1 comentário
- vote for asking the same question three times in 7 hours. Try to stay with your original question please
por
Adicionar um comentário
1 resposta
Solução escolhida
Mark,
The computer is most likely stuck in the digital output mode. If you look in your headphone jack, you will probably see a red light. Most searches for support will suggest a toothpick to disengage the tab inside the headphone jack.
Others have had success by inserting a 3.5mm plug in and out repeatedly until the tab releases and the computer no longer thinks there is a plug in that jack.
Here is more on that.
Good Luck
Frank
Esta resposta foi útil?
Pontuação 2
1 comentário:
+1 Ralph
por
Adicionar a sua resposta
Mark será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 770
