Ir para o conteúdo principal
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
Which LCD Model #/Manufacturer?
I am going to replace the LCD Screen on my newly acquired MacBook Unibody A1278. It is a 2.0 Ghz Processor. unlike the video guide I found, it has the battery door. Is there a specific LCD that I need to get? I have found several sites claiming to have the correct one, but I am worried about them having the specific cable connector.
LP133WX2-TLC1 seems to be the correct part #. Any advice or help would be nice, as I am a very poor traveling musician, and this is something I *need* to get working as cheaply as possible. Also, will a hairdryer be sufficient in heating the adhesive, or will I need a heat gun as the tutorial states?
Thank you.
B
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
While I don't have direct experience with the panels, my searching on Google confirms LP133WX2-TLC1 as an acceptable replacement part.
Good luck!
Esta resposta foi útil?
Pontuação 1
I own a 2009 MacBook Pro a1278 my lcd which i removed today says
LP133WX3-TLA2
Pontuação 0
Adicionar a sua resposta
Ben será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 1,900
