Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
EFI password reset, blinking folder? Death.
I'll get right to the point here. I attempted an upgrade from Lion to Mountain Lion. After the reboot, a blinking folder of ? death occured. Tried every keystroke I could find on the Internet to revive it, to no avail. I've tried to boot from my disk, and also from USB. Using multiple keys, multiple times. Option key is the only key that gets a rise outta my Mac. It displays the EFI password prompt. A password that was set by the previous owner I assume. I've attempted the ram removal trick which only makes a beeping sound. I've tried it with 1 stick in different slots and switching them around. Ugh.. Any other insight would be mucho appreciated. Oh I also bought a new HDD hoping I could just fresh install. Same problems. Help me? :(
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Try this:
How do I reset the firmware password on my MacBook Pro?
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks. I meant to update this earlier. It turns out that I didn't try with the ram in the top slot. That worked. Pulled out the top stick, then the bottom, then put one back into the top slot. Turned it over, powered it up, held down the 4 keys to reset the PRAM and it worked!! Unfortunately, all my mischief under the cover caused my screen not to display a picture. It lights up but is black. :( Not sure what I did yet.
por
how to fix bios password for mac book pro uni body ....It is harware or software to fix it this problem?
Pontuação 0
I think you can try to visit http://www.recoverlostpassword.com
Pontuação 0
1 comentário:
This site is for windows user only., not for Mac
por
Adicionar a sua resposta
mrmjweber será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 5,210
