Ir para o conteúdo principal
iPhone 6 Plus Rear Facing Camera Replacement
O que você precisa
Vídeo de Apresentação
  1. iPhone 6 Plus Rear Facing Camera Replacement, Pentalobe Screws: passo 1, imagem 1 %32
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Plus Rear Facing Camera Replacement, Anti-Clamp instructions: passo 2, imagem 1 %32 iPhone 6 Plus Rear Facing Camera Replacement, Anti-Clamp instructions: passo 2, imagem 2 %32 iPhone 6 Plus Rear Facing Camera Replacement, Anti-Clamp instructions: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Clampy - Anti-Clamp
    $24.95
    Comprar
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6 Plus Rear Facing Camera Replacement: passo 3, imagem 1 %32 iPhone 6 Plus Rear Facing Camera Replacement: passo 3, imagem 2 %32 iPhone 6 Plus Rear Facing Camera Replacement: passo 3, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick or tool under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6 Plus Rear Facing Camera Replacement, Front Panel Assembly: passo 4, imagem 1 %32
    • Use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  5. iPhone 6 Plus Rear Facing Camera Replacement: passo 5, imagem 1 %32
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  6. iPhone 6 Plus Rear Facing Camera Replacement: passo 6, imagem 1 %32 iPhone 6 Plus Rear Facing Camera Replacement: passo 6, imagem 2 %32
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  7. iPhone 6 Plus Rear Facing Camera Replacement: passo 7, imagem 1 %32 iPhone 6 Plus Rear Facing Camera Replacement: passo 7, imagem 2 %32 iPhone 6 Plus Rear Facing Camera Replacement: passo 7, imagem 3 %32
    • Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  8. iPhone 6 Plus Rear Facing Camera Replacement: passo 8, imagem 1 %32 iPhone 6 Plus Rear Facing Camera Replacement: passo 8, imagem 2 %32
    • Several clips along the top edge of the front panel form a partial hinge, allowing the front panel assembly to swing open like a book.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  9. iPhone 6 Plus Rear Facing Camera Replacement: passo 9, imagem 1 %32
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.3 mm screw
    • One 3.1 mm screw
  10. iPhone 6 Plus Rear Facing Camera Replacement: passo 10, imagem 1 %32
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6 Plus Rear Facing Camera Replacement: passo 11, imagem 1 %32
    • Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  12. iPhone 6 Plus Rear Facing Camera Replacement: passo 12, imagem 1 %32
    • Remove the following Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.5 mm screw
    • One 2.9 mm screw
    • Do not attempt to insert longer screws into the red marked screw holes. Doing so may result in irreparable damage to the logic board.
  13. iPhone 6 Plus Rear Facing Camera Replacement: passo 13, imagem 1 %32
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 6 Plus Rear Facing Camera Replacement: passo 14, imagem 1 %32 iPhone 6 Plus Rear Facing Camera Replacement: passo 14, imagem 2 %32
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
  15. iPhone 6 Plus Rear Facing Camera Replacement: passo 15, imagem 1 %32 iPhone 6 Plus Rear Facing Camera Replacement: passo 15, imagem 2 %32
    • Disconnect the home button cable connector.
  16. iPhone 6 Plus Rear Facing Camera Replacement: passo 16, imagem 1 %32 iPhone 6 Plus Rear Facing Camera Replacement: passo 16, imagem 2 %32
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a plastic opening tool to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  17. iPhone 6 Plus Rear Facing Camera Replacement: passo 17, imagem 1 %32 iPhone 6 Plus Rear Facing Camera Replacement: passo 17, imagem 2 %32
    • Finally, disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  18. iPhone 6 Plus Rear Facing Camera Replacement: passo 18, imagem 1 %32
    • Remove the front panel assembly from the rear case.
  19. iPhone 6 Plus Rear Facing Camera Replacement, Rear Facing Camera: passo 19, imagem 1 %32 iPhone 6 Plus Rear Facing Camera Replacement, Rear Facing Camera: passo 19, imagem 2 %32
    Comprar
    • Use a pair of tweezers to peel back the piece of tape covering the hidden screw securing the rear-facing camera bracket to the rear case.
  20. iPhone 6 Plus Rear Facing Camera Replacement: passo 20, imagem 1 %32
    • Remove the following screws securing the rear-facing camera bracket to the rear case:
    • One 1.7 mm Phillips #00 screw
    • One 2.3 mm Phillips #00 screw
  21. iPhone 6 Plus Rear Facing Camera Replacement: passo 21, imagem 1 %32
    • Lift and remove the rear-facing camera bracket off the rear-facing camera.
  22. iPhone 6 Plus Rear Facing Camera Replacement: passo 22, imagem 1 %32
    • Use the flat end of a spudger to disconnect the rear-facing camera connector from its socket on the logic board.
  23. iPhone 6 Plus Rear Facing Camera Replacement: passo 23, imagem 1 %32
    • Carefully lift and remove the rear-facing camera out of the iPhone.
Conclusão
150 outras pessoas executaram este guia.
21 comentários
Great how-to article. I was able to follow it and fix my son's camera within an hour. Patience is key -- take your time and stay organized and you'll get through this.
Josh Gormley - Responder
Great guide, replacement worked a treat!
eric - Responder
I liked How you explained step by step thanks
Reynaldo - Responder
After the replacement the LCD started to freezing.
auwadhablani - Responder
after my replacement with the ifixit camera, my camera twitches and will not focus :(
Brent Conklin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 23
Últimos 30 dias: 74
Duração total: 96,238
