Introdução
Use this guide to replace the logic board in your iPhone 6s Plus.
It's important to note that each iPhone's logic board and Touch ID fingerprint sensor are paired at the factory, so replacing the logic board will disable Touch ID unless you also install a replacement home button that has been properly paired to your new logic board.
O que você precisa
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
Ferramenta utilizada nesse passo:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the following screws securing the antenna bracket to the rear case:
One 1.5 mm Phillips #00 screw
One 2.8 mm Phillips #00 screw
Pry the charge port connector cable up from its socket on the logic board with the flat end of a spudger.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Remove the single 2.8 mm Phillips #00 screw securing the plastic clip to the logic board.
Ferramenta utilizada nesse passo:Standoff Screwdriver for iPhones$5.49
Remove the following screws securing the logic board to the rear case:
Two 2.4 mm standoff screws
One 2.1 mm Phillips #00 screw
182 outras pessoas executaram este guia.
31 comentários
Hello. Good job on these teachings of disassembly. I need help in changing the logic board of my iphone 5 and iphone 6. Where can i buy the logic board? I reside in Nigeria
HI do you know who replaces logic boards on iPhone 6?
I am on Step 29 and the upper-right screw was stripped in manufacturing and I am not able to remove? What is the best way to remove the stripped screw?
if u can melt a pen and stick it on then twist it if that dosen’t work use a dermel cut the screw and use a flahead
