Ir para o conteúdo principal
MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement
O que você precisa
  1. MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement: passo 2, imagem 1 %32
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement, Battery Connector: passo 3, imagem 1 %32
    • Peel back the warning label covering the battery connector.
  4. MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement: passo 4, imagem 1 %32 MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement: passo 4, imagem 2 %32
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement, Heat Sink: passo 5, imagem 1 %32 MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement, Heat Sink: passo 5, imagem 2 %32 MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement, Heat Sink: passo 5, imagem 3 %32
    • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
    • Slide the spudger underneath the length of the cover, releasing the adhesive.
    • Lift the cover and rotate it off of the heat sink.
  6. MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement: passo 6, imagem 1 %32 MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement: passo 6, imagem 2 %32 MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement: passo 6, imagem 3 %32
    • In the same manner described above, release the adhesive and flip back the heat sink cover on the left fan.
  7. MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement: passo 7, imagem 1 %32
    • Remove the following six screws securing the heat sink to the logic board:
    • One 5.5 mm silver raised head T5 Torx screw
    • Four 3.5 mm T5 Torx screws
    • If your model uses discrete graphics, you may have more screws to remove.
    • One 3.8 mm silver T5 Torx screw
  8. MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement: passo 8, imagem 1 %32 MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement: passo 8, imagem 2 %32
    • Grasping the heat sink from one side, lift the heat sink off of the MacBook Pro, pulling it free from the computer.
    • The thermal paste may make it difficult to remove the heat sink. Pull the heat sink off gently but forcefully to avoid damaging any components on the logic board.
    • When installing the new heat sink, do not forget to replace the thermal paste underneath the heat sink. See our Applying Thermal Paste guide for further instructions.
Conclusão
31 outras pessoas executaram este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
503.578 Reputação
Autoria de 407 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 137
Autoria de 17.524 guias
12 comentários
Performed today on 3 yrs old Retina 15" with integrated Iris Pro 5200. Temperatures dropped considerably, both during idle and load periods, but BE AWARE, if you pass control to the fans via i.e.: smsFanControl, during testing laptop reaches abnoxious temperatures (98C) - what it seems is that when smcFanControl is taking over, also throttling is turned off, therefore, when temperature rised you need to rise fan rpm (during Geekbench 3 I set it at the end to the 3800rpm from 2500rpm it was and this dropped immediately from 98C to 70C). When SmcFanControl is set to Default, MAC UEFI controls fans and - what is funny - when load exceeded reasonable thresholds, (one core reached 92C) it throttled (probably) because without much rpm raise - this dropped temps to 75C (Default setting did at critical point two things: a) from 2160 rpm to 2890rpm and b) throttle ... what ended in immediate drop to 75C). Keep that in mind.
In this aspect I consider this as a smarter management.
Michal Wiktorow - Responder
One of the screw thread used to tighten the spring-clamp holding the cpu in place has detached from the motherboard. Is it possible to repair this, and if not, is it fine to hold the cpu with only one spring clamp ? Thanks a lot !
Mathieu Polge - Responder
Hopefully you are still around the forums these days.
You usually can fix something like that if it was soldered to the board, with simple solder and something to hold it in place. However if it was riveted to the board you may have another problem, of which I do not know how to solve. You happen to have a picture?
Quinn Dunham -
The image in Step 7, and the offered replacement part are wrong! In all images except step 7 you are showing the correct hardware, whitha heat pipe including cpu and discrete graphics plates. But in step 7, and in the replacement part offering you show a heat pipe containing only one plate! Please correct this? Where do I get a replacement heat pipe for my macbook containing adiscrete graphics chip? Thank you very much!
Alexander Schukat - Responder
I want to know this as well. That said, I don’t really see the need to replace the heat sink. What’s the problem is that the thermal paste has dried up and no longer conducts as it used to. So simply removing the old heat sink, scraping off the paste and re-applying new paste should do the job just fine. I don’t see in what way the heatsink itself should go ‘bad’.
mv-maynotberead -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 34
Últimos 30 dias: 129
Duração total: 29,499
