Ir para o conteúdo principal
HTC One Speaker Replacement
O que você precisa
  1. HTC One Speaker Replacement, Speaker: passo 1, imagem 1 %32 HTC One Speaker Replacement, Speaker: passo 1, imagem 2 %32 HTC One Speaker Replacement, Speaker: passo 1, imagem 3 %32
    • Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
  2. HTC One Speaker Replacement: passo 2, imagem 1 %32
    • Pry the back loose and lift. The back panel will come off with time.
  3. HTC One Speaker Replacement: passo 3, imagem 1 %32
    • Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
    • Remove the tape gently to find some hidden screws underneath.
  4. HTC One Speaker Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to get underneath the motherboard to lift.
    • Lift gently because the motherboard is not completely disconnected.
  5. HTC One Speaker Replacement: passo 5, imagem 1 %32
    • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
    • Lift the camera from the bottom of the motherboard.
  6. HTC One Speaker Replacement: passo 6, imagem 1 %32 HTC One Speaker Replacement: passo 6, imagem 2 %32
    • Remove the motherboard completely out of the phone.
    • May stay attached from one end by tape.
  7. HTC One Speaker Replacement: passo 7, imagem 1 %32 HTC One Speaker Replacement: passo 7, imagem 2 %32
    • Use the blue opening tool to pry the battery from the frame.
    • Some force will be needed since the battery is glued to the frame.
    • Be careful to not break the battery upon removal.
  8. HTC One Speaker Replacement: passo 8, imagem 1 %32 HTC One Speaker Replacement: passo 8, imagem 2 %32 HTC One Speaker Replacement: passo 8, imagem 3 %32
    • Completely remove the motherboard.
  9. HTC One Speaker Replacement: passo 9, imagem 1 %32 HTC One Speaker Replacement: passo 9, imagem 2 %32
    • Remove the #000 screws around the speaker that are located at the bottom of the frame.
    • Lift the speaker out of the frame.
Conclusão
16 outras pessoas executaram este guia.
Alex
Membro desde: 09/23/14
664 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 12-1, Blackwell Fall 2014 Membro de USF Tampa, Team 12-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G1
Membros da 4
Autoria de 7 guias
2 comentários
Where to buy speaker???
bharatdshmkh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 19,444
