Battery
9 respostas 25 pontos |
Is the SSD upgradeable in the 2017 version? |
2 respostas 2 pontos |
Can MacBook 2016 or newer be iCloud locked PERMAMENTLY? |
1 resposta 0 pontos |
How do I locate the ssd in the A1707 MacBook Pro |
3 respostas 1 pontos |
I broke the battery board data cable connector |
Peças
Ferramentas
Estas são algumas ferramentas comuns usadas para executar trabalhos neste dispositivo. Talvez você não precise usar todas elas em cada procedimento.
Modelos
A1707 (EMC 3162 MacBookPro14,3) 2.8 GHz, A1707 (EMC 3162 MacBookPro14,3) 2.9 GHz, A1707 (EMC 3162 MacBookPro14,3) 3.1 GHz
Technical Specifications
Platform
- CPU: 2.8 GHz quad-core Intel Core i7 (configurable up to a 3.1 GHz Core i7)
- RAM: 16 GB of 2133 MHz LPDDR3 onboard memory
- GPU: Radeon Pro 555 with 2 GB of GDDR5 memory (configurable up to Radeon Pro 560 with 4 GB of GDDR5 memory)
- Storage: 256 / 512 GB PCIe-based onboard SSD
Display
- 15.4-inch (diagonal) LED-backlit display with IPS technology; 2880-by-1800 native resolution at 220 pixels per inch with support for millions of colors
- 500 nits brightness
- Wide color gamut (P3)
Ports and Connectivity
- Four Thunderbolt 3 (USB-C) ports with support for:
- Charging
- DisplayPort
- Thunderbolt (up to 40 Gbps)
- USB 3.1 Gen 2 (up to 10 Gbps)
- Wi-Fi: 802.11ac Wi-Fi wireless networking; IEEE 802.11a/b/g/n compatible
- Bluetooth: Bluetooth 4.2 wireless technology
Camera: 720p FaceTime HD camera
Audio
- Stereo speakers with high dynamic range
- Three microphones
- 3.5 mm headphone jack
Battery and Power: Built-in 76.0 watt-hour lithium-polymer battery
Size and Weight:
- Height: 0.61 inch (1.55 cm)
- Width: 13.75 inches (34.93 cm)
- Depth: 9.48 inches (24.07 cm)
- Weight: 4.02 pounds (1.83 kg)
Operating System
- macOS High Sierra
- Touch Bar runs a modified version of watchOS
