Ir para o conteúdo principal
MacBook Pro 15" Touch Bar 2017 Keyboard Key Cap Replacement
O que você precisa
  1. MacBook Pro 15" Touch Bar 2017 Keyboard Key Cap Replacement, Keyboard Key Cap: passo 1, imagem 1 %32
    • For blowing out the dirt you will need a bellow as they are used for camera cleaning.
    • Do not use compressed air or too much force when blowing. Underneath the key is a fragile black piece of plastic that blocks off some of the key backlight. Too much air pressure can break this plastic making that key permanently lighter than the others.
  2. MacBook Pro 15" Touch Bar 2017 Keyboard Key Cap Replacement: passo 2, imagem 1 %32
    • Use the bellow to clean your keyboard. Otherwise you might end up getting even more dirt into the key after removing the cap.
  3. MacBook Pro 15" Touch Bar 2017 Keyboard Key Cap Replacement: passo 3, imagem 1 %32
    • You need a thin credit card or laminated piece of thin cardboard. It needs to be thin enough to fit into the gap between key cap and casing, but sturdy enough to lift the cap up.
    • Most credit cards might be too thick for the job. I found one in my wallet that was thinner and more flexible than the others and it worked just fine.
  4. MacBook Pro 15" Touch Bar 2017 Keyboard Key Cap Replacement: passo 4, imagem 1 %32
    • Slide the card into the gap between upper edge of the key cap and casing. (For the small "arrow up" key it's on the right side, for the "arrow down" key it's on the left side, for the "return" key it's on the left side.)
    • Gently lever up until you hear two clicks (or up to four for longer keys like shift or space bar). They indicate that the cap is released on both notches.
    • Be careful not to use too much force. All parts of the MacBook keys are quite fragile with tiny plastic notches that can easliy be broken.
  5. MacBook Pro 15" Touch Bar 2017 Keyboard Key Cap Replacement: passo 5, imagem 1 %32 MacBook Pro 15" Touch Bar 2017 Keyboard Key Cap Replacement: passo 5, imagem 2 %32 MacBook Pro 15" Touch Bar 2017 Keyboard Key Cap Replacement: passo 5, imagem 3 %32
    • While lifted up, take the key cap with your fingers and gently pull it towards the display.
    • Again, don't use much force. The cap can easily be pulled when dragged towards the display being fully released afterwards.
    • When examining the back of the cap (second picture) you'll see that the notches on the upper edge of the key cap are designed to be pulled up (left circle) while the lower edge notches need to be slid (right circle).
  6. MacBook Pro 15" Touch Bar 2017 Keyboard Key Cap Replacement: passo 6, imagem 1 %32
    • Using the bellow, blow out dust and dirt.
    • Remember not to use to much air pressure as the vulnerable black backlight cover is now directly exposed. Normal airflow is sufficient to get most of the dust out.
Conclusão
To put the key cap back on, follow the steps in reverse order: First you need to slide in the key cap on the lower edge and then gently press it into the two notches on the upper edge.
17 outras pessoas executaram este guia.
marmuc100
Membro desde: 12/01/20
931 Reputação
Autoria de 1 guia
8 comentários
Does the replacement key come with the transparent plastic cover that goes over white butterfly mechanism? When this is damaged, is it possible to replace the key so it functions as new? Thanks for info.
Marceli Cieplik - Responder
I haven’t bought a replacement key yet so I can’t guarantee this 100%, but I think, that these transparent “sockets” for the white butterfly mechanism are part of the key cap. So I’d guess: Yes, the transparent part is integrated in the replacement key.
If you buy one, I’d be happy if you’d let me know whether this is true! :)
It depends on what’s damaged. Most likely it’s not the key cap but the white butterfly mechanism itself. If you replace that it should work as new. But I recommend to try cleaning as in the instructions above first – for me and my friends keyboard issues with these models always came down to dirt in the mechanism.
In theory, the transparent clips shouldn’t really affect the function of the key. It rather holds the key cap in place, so if these are broken, it is more likely that your key caps don’t stay in place (e. g. are lifted up or slightly turned when typing).
marmuc100 -
I picked up one of these kits from www.laptop-keys.com and they were able to provide the key cap, plastic scissor mechanism and that plastic part the sits underneath. Along with this guide, I was able to restore my MacBook keyboard back to new. Thanks for the great write-up!
Jeff Horton - Responder
Thanks for sharing this! They even seem to ship internationally for about $3, that is really useful!
marmuc100 -
I've just broken two of my MacBook Pro's keycaps while trying to get them out.
Miguel F. - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 17
Últimos 7 dias: 151
Últimos 30 dias: 562
Duração total: 20,759
