Ir para o conteúdo principal
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 Perguntas Visualizar todos
Home button not responding after digitizer replacement, how can I fix?
I've just replace the digitizer on my iPad 2 GSM, and now the home button doesn't respond. I don't see how the home button even interfaces with the logic board, as it seems to just be a small PCB board behind the actual button, that doesn't connect to anywhere... Any ideas of how to fix please?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
10 respostas
Solução escolhida
From my experience the home button won't work if it's not low enoughh to make contact with the contact areas it is supposed to sit on. When you replaced the screen , if there was too much tape put on, the button won't sit low enough to make contact, or if there was not enough tape the screen may not sit close enough to make contact again because when I replaced mine, I didn't have enough tape to hold it tight against the chassis. If it worked before you changed the screen I doubt it went bad just by removing it. Either way you will probably have to take it apart again. Since you have to take it apart again, you could remove the screen, remove the button from the screen and just put the button on the area on the iPad where it should sit and see if you can get a response out of it. It's possible the screen isn't exactly in the same place it was put at the factory when you took it off and put in back on. Since there are no wires to connect to the button it has to sit exactly on the contact points in order to work...hope that makes sense..And I hope that helps..
Let us know what you find out..
Esta resposta foi útil?
Pontuação 2
Same problem...with a twist. The home button worked initially after installing a new LCD and Digitizer but then stopped working. I disassembled the unit again and found that the HOME BUTTON RIBBON WIRE CONNECTOR HAD SLIPPED JUST PART WAY OUT OF THE CIRCUIT BOARD CONNECTOR. After lifting the latch, carefully reinserting the ribbon connector as much as possible and closing the latch...all worked fine. Whew...Life is good again.
BTW, SAVE any parts (like the OEM home button, etc) you replace (okay, not a cracked digitizer) as you never know when you may need them.
Pontuação 2
1 comentário:
if you're talking about the charger port assembly, and the connector off to the left near where the digitiser connects, then, in this case the iPad would not charger either?
I have the same problem (home button not working) but my unit is able to charge Ok so from that I assume the connection is fine.
por
Try putting the home button in from the old screen. I just had this issue too and the design of the OEM button was a bit different (wider contact points) and worked like a charm where two aftermarket replacement buttons did not work.
Pontuação 1
I had the same problem, I also replaced the wifi antenna during this process. The home button connector came loose off the mother board. I took it off and reseated it and then everything worked. The charger is also connected to this. The connection is under the tape that the silver shield protecting the wifi chip is attached to on the bottom left corner of the ipad. hope this helps
Pontuação 0
I had the same problem. When you removed the old digitizer, the thin flex cable from the home button to the volume buttons was stuck to the glue and tour a small piece out on the right side near the top. You will need to order a new home button and volume botton ribbion cable.
Pontuação 0
2 comentários:
You're referring to the Power-Mute-Volume flat cable. This discussion is about the home button located at the bottom of the iPad.
por
The home button has nothing to do with the power/volume/audio flex cable. It is a standalone button at the bottom of the iPad.
por
is the last comment referring to the power button and not the home button???or does the power/volume ribbon have to also do with home button....because i replaced mine after putting it back together it didnt work....well i jumped up awhile ago and it hit me........i never did a hard reset to get it back!!!....works but now my home button doesnt work.....i will try top answer but think maybe last poster meant power button.....i could be wrong .
Pontuação 0
1 comentário:
He's referring to the Power-Mute-Volume flat cable, like you guessed.
por
The two gold plates on the home button assembly connect to two gold prongs on the ipad. These must be properly aligned. Ensure you re-assemble the wifi antenna off to the side in its correct place and not over these two prongs.
Pontuação 0
I just have the same problem. I tried with more/less tape, and tried to "build" down the home button connector, but still no success.
I had some other replacement screens in my store. And when I tried a new one, it works... no problem with the homebutton.
Pontuação 0
Found that the female connector was not gripping the push button cable tightly. Used a drop of "5 second fix" uv activated glue to hold it in place.
I also found that when the digitzer was pushed down flush with the bezel along the bottom edge by the home button, the home button would not work again. Problem is that home button did not perfectly align with the cut out in the aluminum housing. Bottom outside edge of the button hit the inner edge of the aluminum chassis cutout. I placed a second layer of double sided tape with a tiny bit over the home button wings. That raised it just enough for a tight seal and good button function with a nice click.
Pontuação 0
1 comentário:
FYI, this is referring to an Ipad 4
por
I have a iPad 2 and a thought I fixed the touchscreen but the home button isn’t working. Any suggestions please?
Pontuação 0
Adicionar a sua resposta
David S Burns será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 28
Últimos 30 dias: 96
Duração total: 37,415
