Ir para o conteúdo principal
The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
315 Perguntas Visualizar todos
Upgrading a MacBook Air A1466 (2014)
I got this MacBook Air A1466 bought in 2014, from a friend. The laptop is working quite well, maybe it’s a bit slow but it’s ok.
I would like to extend the life of this little device and I’m thinking of installing a Linux distro and upgrading some hardware. Apart from the battery (it gets to 70% max) what other parts can I upgrade in your opinion?
  • RAM 4 GB 1600 MHz DDR3
  • Intel Core i5 dual-core
  • 250 Gb SSD
  • Intel HD Graphics 5000 1536 MB
  • Wifi 802.11ac
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Your options are quite limited! If you have a Core i5 1.4 GHz you could replace the logic board to get a more powerful CPU Core i7 1.7 GHz. As the RAM is also soldered on the logic board you could also get a replacement board with 8GB as well.
The SSD drive is upgradeable on its own! You can find Apple custom SSD’s as well as third party from OWC or Transcend which both make the fully compatible SSD’s. Using anything else just won’t last as they don’t fully integrate to Apples interface.
The graphics and display is not upgradable. The WiFi & Bluetooth are the same for both boards. So its is what it is. I really doubt you need anything faster given the generation of the CPU’s.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Andreac será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 52
Últimos 30 dias: 189
Duração total: 5,254
