Ir para o conteúdo principal
{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
277 Perguntas Visualizar todos
MacBook Pro 2017 screen flickering / glitching / has horizontal lines
My macbook pro screen has started started glitching all of a sudden and I am unsure why. I have tried the following :
  • Restarting
  • Resetting SMC
  • Adjusting display settings
Does anyone have any other solutions for this issue?
Esta é uma boa pergunta?
Pontuação 8
4 comentários
Can you post a few pics or vid so we can see what up Adicionar imagens a uma pergunta já existente
por
@danj Hello Dan, I have added some now
por
My MacOS screen now very bad in 18%
Ther some: Flicking, Glitch, Bad Quality, Many Black Screens, Lags and Viruses
por
I hаd a similar іѕѕuе, Mу Mac had flickering lines.
Fіnаllу I mаnаgеd to resolve thе problem after doing some research.
Follow thіѕ guide hеrе: https://smarturl.it/MacFlicker
Hope thіѕ helps
por
Adicionar um comentário
2 respostas
Solução escolhida
Not good ;-{
Your T-CON board has failed likely from over heating. Either you tend to use your system on your bed or rug which blocks the vents or you run your system hard playing heavy graphics games or video editing.
Here’s the needed part MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and here’s the guide MacBook Pro 13" Touch Bar 2017 Screen Replacement
Imagem de MacBook Pro 13" Retina (Late 2016-2017) Display Assembly
Produto
$454.99
Esta resposta foi útil?
Pontuação 2
Hi Dan,
I just started having the same issue, so thank you very much for the answer. I have almost no doubt I’ve overheated the TCON board. I have some follow-up questions, whenever you can:
  1. Do you have some idea how much Apple would charge to make this replacement out-of-warranty?
  2. Are the 2020 Macbook Pros (13-inch, Intel i5 processor) set up the same way internally, i.e. with the TCON board between the heat sinks? And are they any better at not overheating? I guess another way to phrase this question is, are the newer Macbook Pros any better at avoiding this issue?
  3. I will definitely look to install a temperature monitor in the future...what is a safe range to have the temperature to avoid running into this issue again?
Totally understand if you're not in the place to answer some of these questions. Any help would be greatly appreciated!
One more quick question: is this issue one that tends to build up over time or can happen in one instance of misuse?
I'm just trying to self-diagnose what processes may have led to this happening.
Pontuação 0
Adicionar a sua resposta
Sunny Lee será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 16
Últimos 7 dias: 59
Últimos 30 dias: 280
Duração total: 23,977
