Ir para o conteúdo principal
A versão somente wi-fi do Air iPad, da Apple, modelo número A1474. Disponível nas cores cinza espacial ou prata, conta com o processador A7 personalizado, com configuração de armazenamento de 16, 32, 64, e 128GB.
299 Perguntas Visualizar todos
iPad turns on when plugged in but wont charge
I plugged my ipad into the wall when it is on and wont charge but when I turn it off and plug it in it will power on like it detects the charger but wont charge and also not recognized on my computer
Esta é uma boa pergunta?
Pontuação 0
3 comentários
I tried 3 chargers 1 of apple 1 after market with certification and 1 with out only 1 that turns on the ipad is non certified 1 ipad dosent respond to any other cable
As far as I can tell it looks good inside the charging port
I can check with 3utools since the computer isn't recognizing the ipad
I sadly don't have USB ammeter to check
I've also tried a battery swap and it still doesn't make a diffrents
por
Most likely the Lightning flex, I change these all the time...
por
same thing happends to me i cant find a fix its been like this for 4 hours
por
Adicionar um comentário
1 resposta
Solução escolhida
Hello Jayden. When troubleshooting charging issues, I would do the following (in order):
  • Always try another Lightning cable and charger, preferably Apple original or MFi certified units.
  • The Lightning cable 8-pin connector should be sitting flush with the housing and completely inserted. If it is not, there could be lint/dust/debris inside the port impeding a proper connection. You can clean it out with a toothpick, fine point tweezers or a dental pick. Just be careful not to damage the pins inside the Lightning Port.
  • Change the battery. The battery is the weakest link and certainly for charger related issues. It is also the easiest thing to replace. Use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows) to test the battery prior to removal. Anything less than 70% of design capacity will require replacement.
  • If the battery is in good condition, you can use a USB Ammeter to determine if the device is really drawing current when it says it's charging. If it isn't drawing current, then I would change the Lightning/Charge Port. The iPad Air has a well documented history of charging problems. Over time, it loosens within the housing and this causes the flex, at the point where it connects with the port, to crack. This repair requires some micro-soldering.
Esta resposta foi útil?
Pontuação 5
1 comentário:
I’m having this issue. What’s cost to replace battery.
por
Adicionar a sua resposta
jayden gumb será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 33
Últimos 30 dias: 227
Duração total: 4,485
