Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
776 Perguntas Visualizar todos
iOS devices connecting and disconnecting rapidly.
I've been having this issue for a while with my iPad Air 2: When I plug it into my MacBook, it will act as though I am plugging it in and unplugging it rapidly, and will not stay connected long enough for me to sync or backup with iTunes.
My iPhone has connected perfectly until today, when it started doing the same thing as the iPad. All other USB devices work fine, and my iPad and iPhone both connect with the windows computers at work just fine. I've tested with both USB ports on my MacBook, and with several known working cords, both Apple branded and not.
I've done a lot of searching, and haven't found any definitive answers or solutions, but today I thought I would try something.
I use Windows 10 in VMWare on my laptop for work (and yes I made sure it wasn't running before trying to sync to make sure that wasn't causing the connectivity issues). But today I opened Windows on my MacBook, and when I plugged in my iPad I told it to open in Windows, and voila it connected to iTunes in windows fine and stayed connected.
This leads me to believe it is some sort of software issue on the MacBook side of things. I even tried closing itunes and just plugging my phone in to charge, and it again acted as though I was continuously plugging it in and unplugging it, but stayed connected in Windows.
Is there something I can do to correct this? I thought it might be an iTunes issue, but since it wouldn't even keep my phone connected enough to charge without iTunes open, I'm assuming it's an OSX issue.
Any suggestions would be greatly appreciated!!
Esta é uma boa pergunta?
Pontuação 60
32 comentários
I had this issue for over a year. Today I stumbled across a page that said to do a SMC reset and now it is all fixed!! Shutdown the Mac and connect the power cable. Hold down Shift+Control+Option+Power all at the same time for a few seconds. The light on the power adapter will blink or change colour once you remove your fingers (all at the same time). When it does this you’ll know ths SMC reset is complete. Turn your MacBook on by hitting the power button like normal. It should be fixed now
por
I had this problem connecting two devices at once through a USB hub Now realise it was because the power was coming from a low power wall charger 5v and it was trying to charge the MacBook as well
por
I had this problem and solved it by buying a powered USB port that provides external power to the devices that I plug into it. I bought it for CD burners, but now I use it when plugging in my iPad into my Mac
por
Tried everything, the only thing that works, is charging my iPhone 11 and 8 to 100%, then the disconnecting solved.
por
Tried reset location & privacy. Didn't work. I swap with another cable (also genuine from Apple), problem solved.
por
Exibir mais 27 comentários
Adicionar um comentário
34 respostas
Solução escolhida
You need to reset the privacy settings in IOS, then it will recognised again.
If you have not connected your iPhone to your computer in a while and the computer was updated with new software, there could be some trust settings issues. In order to check and resolve this issue, Open your iPhone, tap on Settings > General > Reset > Reset Location & Privacy.
Esta resposta foi útil?
Pontuação 65
44 comentários:
solved my problem.
por
I have been looking for a solution for this for over a year. Thanks for solving my problem.
por
fixed my problems also, thanks been trying to fix this for months
por
Did not help... still the same...
por
worked like a charm
por
Exibir mais 39 comentários
Pergunta mais útil
Sometimes, the issue is purely a software one. Occasionally, there are problems with usbd daemon programme, which is the root of the issue with the iPhone.
A possible solution to this problem is to open Terminal.app (Applications -> Utilities -> Terminal) and execute the following command: sudo killall usbd . It will kill the programme and it will immediately relaunch. You will need to provide your password. Please note that the password will not be visible, it is normal.
If it does not work, try entering a different command in Terminal: sudo killall -STOP -c usbd . Once more, you may need to present your password
Pontuação 419
270 comentários:
THANK YOU SO MUCH!! I tried everything else here and this is what finally worked :)
por
Bless you! I've had this issue for so long and this finally fixed it. Thanks a bunch! :)
por
This fixed mine !!!!!!!
por
been trying to fix this for months. this is what worked. thanks!!!
por
It works! I did the commands with my iphone plugged in, and it immediately stopped the annoying vibrating, and connected.
por
Exibir mais 265 comentários
I also had this problem with my iPhone 6 and MacBook Air with an original Apple cable that works fine when charging normally, so it had to be something with the computer.
I chatted with Apple customer support and they told me to update to the newest OS-X and do an SMC reset on my MacBook Air. It’s easily done and did the trick for me. They also told me I could try an NVRAM reset, but this was not needed in my case.
Hope this can help someone!
Pontuação 9
8 comentários:
it helped me. Thank you so much. I had to update and NVRAM reset
por
I was having this problem for more than two years. Finally today, I have updated the latest OSX and then done an NVRAM reset. Cheers, my iPhone is connecting very smoothly with my MAC. Thank you so much.
por
Unfortunately I have tired everything, and both these options did not work either.
por
the second command with STOP finally resolves the issue. THANKS!
por
Worked temporarily, then started it's nonsense again...
por
Exibir mais 3 comentários
After trying all the recommended fixes for this issue in all the different forums I could find (new cables, privacy setting resets, full system reset etc) I still had the problem so I have come up with a work around.
I now plug all my devices - iPad, iPhone - in to a USB multiport and then connect the multiport’s USB cable to my MacBook air. Problem solved!
I’m using the Belkin 4-Port USB 3.0 Powered Hub! - Which I’ve plugged in to power as well as to my Mac.
Basically, letting the Hub power my devices Vs my Mac.
Pontuação 9
5 comentários:
THIS!! this is the fix! all the other answers botted me but this truly works my g, this just worked with a standard USB powered hub for me aswell,
por
This worked! Ugreen 4 way 2.0 splitter
por
This is the answer. Make sure it's a powered USB hub though, because the issue is that the phone is drawing too much power and the laptop 's USB can't handle it for one reason or another.
por
In my case I was plugging my iPad on a powered USB so I don't think power was the issue. However the problem was, it's now working properly after using an old usb hub. THANK YOU !
por
This was it for me?!?! Not sure why this made a difference but thank you so much
por
Mine always does that. I think it's because battery is not charged enough.
I can only connect successfully when my MacBook Air battery is 100% even then it takes a second try :) .
I think it doesn't get enough energy from USB when battery is not charged enough. So it keeps try to get enough voltage and fails. I haven't tried but maybe a shorter cable would fix our issue.
Try when your battery is full. You'll see it connects successfully.
Pontuação 5
3 comentários:
This also happens when the battery is low and when the Macbook is not connected to it's charger. Try connecting the Macbook to a Charger and then connect the lightning cable. This has helped a lot of times for me.
por
I have also found it to help when I've plugged my Mac into the power outlet - but not always. :/
por
Worked like a charm (the second command). I had been trying everything for the past couple of days searching for a solution online, but nothing seemed to help. I finally landed on this page and by God's grace came across your posted solution. God bless you; you're an angel. You literally saved my iPhone.
por
After a long time with this issue, my conclusions:
  1. some of us are having this issue because of a board design issue, current demand from our USB device(iphone/ipad) is higher than mac USB can provide, as a result the port fails.
  2. You will see this issue more frequantly when your device pulls more current - when it has low battery and tries to quick charge or when you use a high demand devices(ipad/Plus/Max)
  3. when only the SUDO KILL command helps you have the 1 & 2 issues i wrote.
Pontuação 5
4 comentários:
I had this problem with some iPhones and my 15” MacBook Pro Retina, Mid 2013.
I switched from my normally used Left USB-port to Right USB-Port, now the iPhone keeps connected!
por
This worked for my MacBook Pro 15" 2014 running Mojave and iPad Mini 2!
por
Didn't expect this to actually work but it did, thanks.
por
Yes !!
I have tried the Terminal command, it did work once (I now think sit was a coincidence - just enough power in macbook and iphone). I gave up on PRAM etc etc resets years ago, they never do anything useful. Of course I never bother asking so called 'geniuses' or going to Mac's forums. I suspect the lack of power, even now with a 90% full iPhone and 98% full on my macbook ! this is the issue. Insane the board isn't capable of delivering a data feed between both, yet another ridiculous mac fail.
SO, I have to say, this is the most reliable solution I have found ... the right hand USB seems to have a better power management and less likely to break data connection. THANK YOU.
por
I have the same problem and had not been able to resolve it.
When I connect the very same iPhone with the same cable, through a USB 3.0 hub connected to the MacBook the iPhone gets connected instantly without any issues.
Pontuação 2
2 comentários:
Same here, just been trying to search for a solution for years but finally I figured out that that problem doesn’t come out o rarely, with a fully charge battery on Mac and like 100% doesn’t come out using a 3.0 usb hub
por
SOLVED.......
This worked thank you!!!
por
@James Tompkins, it lets you type the password, it's just NOT shown to you as a security measure. Just type your password completely and press enter
Pontuação 2
Well, crap. I switched from my trusty old 15” mid-2012 Macbook Pro to a 15” mid 2015 Pro. I ran into this same infuriating issue with my iPhone XS. I actually have two 15” 2015 Macbook Pros on hand at the moment, and it’s doing it on both. Running the sudo killall -STOP -c usbd command fixes it, until I reboot or wake the computer as others mentioned. Plugging in my 6S Plus is better, it usually works, but still does it occasionally on one of them. You can bet Apple will hear from me…
Update (12/17/2019)
Mine is working now. Apple serviced my mid-2015 15” MacBook Pro, replacing the motherboard and I/O board. (so they said, it still has the same serial number) I did notice one thing before I sent it in. As long as it was running macOS Catalina, I had no issues. Downgrading it to Mojave brought on the issues. Upgrading back to Catalina made it go away. However, it was not strictly software specific. The Genius Bar tech replicated it with ease using a triage drive in store. Once I got the laptop back, I reinstalled Mojave out of curiosity. I was still able to reproduce it a time or two, but it was much more reliable. Now that I’m back on Catalina I have no more issues. I now like this laptop except for the pathetic keyboard feel.
Pontuação 2
2 comentários:
Having the same issue,during the 14 months of xs max ownership I’ve battled every time to get it to sync to my MacBook 2012 running the latest software,where my wife’s iPhone 7 and three iPads have no issues,I’ve blamed my iPhone thinking the port is blocked with fluff,I’ve blamed cables which some do work better than others,eventually I bought a powered usb hub and it’s sorted,though in the meanwhile I’ve uploaded everything to google drive because I have no faith in my MacBook or Apple anymore
por
This one is actually which helped me.
Disconnected iPhone > Fired `sudo killall -STOP -c usbd` in terminal > Reconnected iPhone and it worked :)
I am using MacBook Air (13-inch, 2017)
por
You may have a USB port issue. Have you tried the other port as well as a different Lightning cable?
To test the system this device is quite useful: USB Mini Voltmeter
Imagem de USB Mini Voltmeter
Produto
USB Mini Voltmeter
$9.99
Pontuação 1
4 comentários:
If that were the case though, the iPad and iPhone shouldn't connect to Windows being virtualized on the same laptop, correct? They connect and stay connected fine in VMWare, just not when they try connecting through Mac OS. And I specified in my post that I tried both ports and multiple cables.
por
The Windows VM is connecting via the Apple driver within MacOS so I can't explain why Windows appears to work from within the VM.
I was trying to eliminate the possible hardware types of issues I more often see which is power issues within the USB port.
So if we assume its not hardware then its software within your system. I was trying not to go down this path as it would require a complete wipe of your drive and re-install the MacOS and then test your iPad/iPhone within iTunes with nothing else running.
Then if this worked slowly re-install your Mac apps (from the Apps Store) then after that re-install your VMWare and Windows (from original source images) testing things as you go. Once you got your apps all loaded run a good Anti-Virus/Malware on your TimeMachine backup to make sure its clean and then restore your stuff.
por
This is happened because macOS wants to charge iPad and tries to give 2A through the USB 2.0 cable, which had to be impossible (because USB 2.0 can give maximum of 1A). But Macs can do it anyway (idk how). So especially on notebooks it can fail. Of course, Windows VM won't try to charge iPad, so it would work perfectly. And when we type "sudo kill" we prevent macOS from giving high current and iPad labels "No charging", but it works flawlessly.
por
@Владислав Потаенко - Review this: If a Mac accessory needs more power or is using too much power and About USB on Mac computers
USB 2.0 - Up to 500 mA at 5V
USB 3.1 Gen 1 - Up to 900 mA at 5V
Extra Operating Current: Mac computers and Apple displays introduced after 2006, when directly connected to certain Apple devices such as iPhone or iPad, can provide extra power over one or more ports. The Mac or display must be powered on and awake to provide this extra power. A Mac started from the Windows operating system doesn't provide extra power. USB 2.0 /3.0 - Up to 1.600 mA at 5V (1.6A a 5V)
por
I solved that problem by a slightly change cable position .... :)
Pontuação 1
1 comentário:
yes that's was helpful thank you p
por
i kept my phone connected to my mac and turned it off for 5 minutes before turning it back on and it stayed connected!
Pontuação 1
I have the same problem, and had not been able to resolve it. When I connect the very same iPhone, with the same cable, but trough a USB 3.0 hub connected to the Macbook, the iPhone gets instantly connected without any issues.
Pontuação 1
If you connect through an Apple USB wired keyboard USB port it works fine!
If you don’t have a USB port in the keyboard you may be try a cheap USB hub.
Pontuação 1
WOW. This actually worked for me too! I had an OLD hub lying around... worked first go. Frustrates me that I had to go through everything else, and this ended up being the solution!!
Pontuação 1
I had 2 problems.
  1. Your iPad could not be activated because activation server cannot be reached. Try connecting your iPad to iTunes to activate it, or try again in a couple of minutes." "If this problem persists, Apple Support at apple.com/support."
  2. ERROR 9 trying to update or restore it in system restore.
I tried virtually everything to no avail trying to restore an old iPad 2 with both the activation AND error 9 problems. finally i took the advice of using a USB hub AND force terminating usbd before iTunes finally recognized the iPad and starting restoring it.
PHEW.
Pontuação 1
1 comentário:
Your systems USB port power services is having problems!
This is a common issue in the older Unibody MacBook's & MacBook Pro's with iPads as they need more power than what your system can offer. For iPhones I've seen this before when the systems logic board has issues,
por
I was able to solve this same problem with my iPhone 6s by restarting the phone. It was not the solution I was expecting, but after trying different chargers, computers, and USB hubs, this is what ended up working.
Pontuação 0
2 comentários:
restarting the phone did not help in my case. Neither did the stop command in terminal. My issue first noted after updating to Big Sur and also changing some ram.
por
Over the course of three years I think I understand it to be an issue with my MacBook Pro 15" (2015), which seems to have had voltage regulation and battery problems since I acquired it used from a friend. It would tend to not be a problem when the phone or iPad was charged over 90%, but there was no consistency in this. I've finally given up on this great, but ultimately heavy and aging laptop, since it now abruptly shuts down when reporting over 30% battery life left. (Yes, it gives the ominous "please service battery" message.)
por
When you are running a VM, make sure you have your iPhone connected to your Mac explicitly.
Pontuação 0
Same Issue lasted for 2 yrs… No way to solve it but…
When i went to the apple store to change the battery of my mac (15”, mid 2015 ), and they changed all the top case including battery keyboard and touchpad, the issue has gone.
So for the ones that have this problem I suggest to change all the topcase, that include the battery.
Bye!
Pontuação 0
1 comentário:
Update: Problem re-appeared.
So: Mojave
por
I’ve had this issue on both USB ports of my mid-2017 Macbook Air. It usually “settles” after a bit of time but not without much frustration, often when I really need my battery charged (when my iPhone 7 is at 2-3% especially.)
It’s really bothersome, but I’ve just tried resetting the privacy settings and I hope that will help.
I’m also using the original Apple charger included with my phone, so I’m not sure that’s necessarily the culprit.
Pontuação 0
1 comentário:
Make sure your personal Hotspot is switched off, as i found if my Mac is connected to Wi-Fi this will happen until i switch off Hotspot. Looks like the Wi-Fi and Hotspot are clashing.
por
Excellent!
I have had this same issue with iPhone 7s and now with iPhone Xs for years and this has solved the problem!
Thanks !
Pontuação 0
This didn't work for me. I've updated everything, but I still have the rapidly connecting/disconnecting issue. Very frustrating!
Pontuação 0
1 comentário:
Me too! My phone just keeps rapidly connecting/disconnecting so annoying have Have you found a fixed yet@rickmckay65
por
I’m trying to run the Kill commands and when I do it says password with a little lock... but it won’t let me type my password? Anyone know how to do this? I can’t plug my new phone into my new MacBook :(
Pontuação 0
1 comentário:
Mine is the same way. Type the password anyway and hit return. It really is getting your input. I know: crazy.
por
I have tried literally everything I read on internet and still couldn’t fix it,
So I turned off my MacBook and turned it back on while iPhone was still plugged in, it connected and stayed connected! When I unplugged it and tried it again it kept doing the same connecting/disconnecting thing.
So I would suggest just restart your MacBook while iPhone is still plugged in USB port and see if it solves the issue.
Pontuação 0
For some reason it seems to connect sometimes and stay connected at the most random times… and everything else I use works fine with the port so I know it’s working correctly.. but what you suggested seems like a great idea! I’m going to give that a try.. thanks !
Pontuação 0
It’s connecting but once it gets to the Itunes part where it tells me to trust this computer for itunes, the pop-up will not show in my iPhone. I will press continue and wait for my phone to pop-up something but nothing comes up.
Pontuação 0
I tried the command: "sudo killall -STOP -c usbd" but when I turn it off or close the mac and connect the iphone again, it happens again. There is no definitive solution? I have a MacBook Pro 2015 and I tried with iPhone XS and iPhone 7 plus.
Pontuação 0
3 comentários:
It’s hardware issue. There is no way to fix this permanently without fixing underlying issue. Perhaps a hot fix could be writing a script that does it on startup (if you know how to), but I am too lazy to do so, so if you don’t know how to, I suggest googling
por
@solsergiani the sudo command just pauses the process until next reboot, so you’ll need to enter it each time you restart your Mac.
I created a little Apple script to run the sudo command but just have the command saved somewhere or just scroll up in your recent terminal commands by pressing the up arrow on your keyboard when in terminal to find the command again.
On a side note, I’ve had my MacBook Pro (11,3) fixed just this morning, I’ve had the IO board and MLB replaced and the same issue still occurs with various iPhone XS’ at the Apple Genius Bar.
Apple phone support will escalate this to their engineers (again), but it’s only affecting certain Macs (possibly just MacBook Pros?) and iPhones (particularly XS). So sounds like there’s a security/software issue if it’s affecting certain Macs/iPhones
por
it affects by MacBook Air 2013 and iPhone 6s pair also.
por
if sudo commands does not work please try to reset NVRAM
ref: Fix iPhone keeps connecting and disconnecting from Mac
Pontuação 0
2 comentários:
Hi Ricky
I put the codes in terminal and it fixed the problem with our I phones connecting then not ,
but maybe it’s a coincident a day or 2 later my MacBook Air wouldn’t read my external hard drive Which has never happened, which is now my other problem I’ve done the obvious of trying swapping cords etc etc I have older hard drives that all are read by the computer so maybe this is all just a coincident
Any thoughts or anyone ever come across this ?
por
@ad8 Running the sudo command to stop usbd process shouldn't affect non-iOS devices, as the usbd process just configures USB connections for iOS devices. So external drives shouldn't be affected.
If you really worried that it does, you can run the sudo command:
sudo killall -CONT -c usbd
This will restart the usbd process. Alternatively you can just restart your mac and it'll restart the process next time your iOS device is connected.
por
I have the same issue when I use a external USB wireless mouse. After I unpluged everything, the iphone stay connected with no problem.
Pontuação 0
1 comentário:
The USB plug for the mouse is drawing too much power.
por
I did two things simultaneously. i did the shutdown, hold power button on for 10 seconds, then wait 4 seconds, then press power on a gain to restart, but I also changed to a non-hubbed USB port ie I directly connected to computer.
Pontuação 0
I have noticed that this issue is linked with Charging. When I remove the charger, then there is no disconnection.
Pontuação 0
May 2 2021
I have same problem, but when I connected an external usb hub and connect my iPhone to the hub, the MacBook automatically detected the iPhone.
Pontuação 0
Whenever we have this kind of problem what we should do is reset the network setting to defaults. After that set a strong network security key and update network adaptor drivers too.
And yes keep audit and manage your virus removal software too.
Pontuação 0
(Not Solved yet)
I have the same issue here. I have two Macs and one Windows 11 PC (which does not have a USB power delivery issue).
It rapidly connects and disconnects when I try to connect my ipad pro 12.9 (2021), only when I'm connecting with the Windows 11 PC.
It works fine connecting with all the Mac computers but doesn't work at all. It seems to be purely a software issue and can't find any solutions. This didn't happen with my older windows PC. Began happening after upgrading to this recent PC. Maybe a Windows 11 issue? (older PC had Windows 10 installed)
Honestly I thought Apple was trolling with the Windows users in order to make people buy more Macs.... I have been using Mac computers for 15 years over 10 devices from Apple and I became so cynical after all those years I wouldn't be surprised... I tried everything I could think of and I'm an engineer. This Sucks...
Pontuação 0
Adicionar a sua resposta
Rick será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 44
Últimos 7 dias: 352
Últimos 30 dias: 1,428
Duração total: 420,592
