Ir para o conteúdo principal
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Perguntas Visualizar todos
No Display and Repeating Charge Chime
Hello, I have 2 iPhone 4's on Verizon. I wanted to swap the screens on them since one is in locked and the other one is shattered. After a very long process of lost screws and frustration I finally have the good screen on the good phone. The only thing it does now is show up in iTunes and keep making the charge chime. I have put the other board in the housing and it does the same thing. I have even tried the cracked screen on both boards and the same thing happens. I would really appreciate it if you could help me out.
Esta é uma boa pergunta?
Pontuação 2
2 comentários:
Sounds like either board damage or both the screens got damaged from improper installation.
por
I have the same case, except my screen is shattered. The screen worked like that though, and my phone is a little rough, any fixes anyone?
edit: havent replaced the screen yet, its just like this
por
Adicionar um comentário
1 resposta
Very unfortunately, Dylan, your 'good screen' is probably bad. Exactly what you observe (no display and repeating chime) indicates a broken or missing screen. You have my sympathy: replacing iPhone 4 front/screen assembly is onerous. Too I broke an otherwise operational screen, by bending its cable.
See Wiki page: iPhone endlessly repeats the "power supply accepted" sound or vibration.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Dylan Mclaughlin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 20
Duração total: 316
