Ir para o conteúdo principal
Freezing issues on start up.
I've been having an issue with my xobx. It could freeze any where between 10 sec.-2 mins. No red ring of death is seen on the front though. I notcied that i can play DVD's with no problem at all; The issue is when the unit picks up processing speed like when you start a game(you can hear it do this)- then it freezes. Any thoughts? does this sound like the red ring of death without the red ring??? help!!!
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
10 respostas
Pergunta mais útil
Your console can get dust inside of it and that may be one of the reasons as to of why it is freezing. This happened to my console as well. All you need to do is use a can of air to blow out most of the dust that is inside of your console. This worked for my console.
Esta resposta foi útil?
Pontuação 4
FIX FOR XBOX FREEZING ON START UP
For anyone experiencing a “freeze up” upon start up of your Xbox console (meaning Xbox fails to load its dashboard and hangs on profile sign-in), following the instructions below:
Xbox is currently working on fixing a major issue with its auto sign-in feature, so relax, your Xbox is not toast.
Turn off Xbox console.
TURN OFF HOME ROUTER.
Turn on Xbox.
Your dashboard should now load.
From the Dashboard, navigate to SETTINGS.
Find and TURN OFF AUTO SIGN-IN for Xbox and Messenger (if applicable).
Turn off Xbox.
Turn back on home router.
Wait for router to initialize.
Turn Xbox back on.
Load a game.
Now sign into your profile from within the game by pressing the Xbox Home button and choose your profile.
This is a temporary fix. Microsoft is currently working on a patch that will be downloaded to your console when ready. This will allow you to turn back on the auto sign-in feature.
Pontuação 3
2 comentários:
Thank you for this. We have tried everything and my son's xbox was still not working. We were just going to send it in for repair and checked the internet one more time and tried your advice and he is now happily playing on his xbox! Thank you!!!!!
por
I cant use the home router to turn it off... my mom would get mad at me.. :(
any other solution?
por
It looks like it is a pretty common problem :( here is the Microsoft answer to the problem and it looks like they are awre of it. http://support.microsoft.com/kb/907586/ good luck and let us know what works for you.
Pontuação 2
The first issue I ran into with this was realizing that if you plug the power supply into a surge protection strip, it will almost always lock up. The best way to prevent this is to simply plug it into the wall. Make sure it's got a lot of air and isn't in a tight place. Otherwise, you'd have to get a bit more techincal with it, often involving replacements. It's not nice to spend the 100 for a repair, but I would not recommend doing unapproved procedures, as Microsoft can and will check for these if you try them. If you send it in, they will give it back reporting that they will not attempt to fix an opened unit.
Pontuação 1
Try keeping the Xbox running for an hour because it might need heat inside it for the things that is in it to work properly this is only my opinion
Pontuação 1
I'm also having a kinda same problem it gets stuck on intro screen on Xbox logo or on the ribbons with black line on one of the green ribbon
I hav watched many videos on YouTube but never see a black line on Xbox Intro screen
Can anyone helpme out
Have dust cause this issue for which black line appears ?
My warranty is also over else I would have sent it to Microsoft
Pontuação 1
When it freezes, are you able to go back to the dashboard by pressing the eject or guide button?
If not, then your 360 is about to get the rrod. You should get a reflow done. Do not do the overheating trick with the rrod repair kit that a lot of people around here are recommending.
Pontuação 0
1 comentário:
no, when I turn it on most of the times on my controller it is still spinning green . And the dashboard doesn't work the tv is white and I have no hdd cable
por
my does the same whyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy
Pontuação 0
This is happening to me too, one minute I am happily playing Skyrim.. (then it froze, I left it on all night :( but this has happened before.) I tried doing what Microsoft said on their website, but then this update came up and I cant update it because I don't have enough storage because I had to take my hard drive out again, so when I pressed no for the update it froze, every single time. I am dying to find out what is causing it (I might check the hard drive again...) or try to hook up my Xbox 360 to my computer.
Pontuação 0
i was updating xbox 360 , during update my installation were hang, i think it will update , i wait 1 hour , then i restart the xbox 360, it start but nothing show on the screen and in the beginning the xbox 360 start button light green in the ring and then suddenly turns the ring light or change permanently the ring into red , and then freeze .
i open the xbox 360 , but cant finding any reset clue in the xbox 360. any one have any idea how reset the factory, Microsoft builds &&^&^$^ $@$* products, i waste my money.
Pontuação 0
Adicionar a sua resposta
jays113 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 17
Últimos 30 dias: 90
Duração total: 72,140
