Ir para o conteúdo principal
The first of the new generation Nokia devices – the first with a 1080p screen, the first with a quad-core Krait processor
55 Perguntas Visualizar todos
wont power on, flashing windows logo?
Replaced screen assembly, upon charging to test, it will not power up and the only response from plugging in a charger is the windows button flashes repeatedly. I have read that that means a severely drained battery but that is not the case here as i left it charging for 8 hours with no change. Also cleaned contacts and tried unplugging and replugging battery. Even tried windows software recovery program but the phone will not connect to the computer. Also tried a soft reset. Help?
Esta é uma boa pergunta?
Pontuação 6
1 comentário
Anyone? Im sure there is someone who can shed some light on this?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
what I did is I used another nokia to charge the battery and then it worked fine
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Austin Harris será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 23
Duração total: 4,653
