Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2203 Perguntas Visualizar todos
Location of pressure contact
Recent replacement of iPhone 4S battery went well and phone works fine but I'm not sure I replaced the pressure contact correctly: I screwed it down on TOP of the battery connector and I think it may have originally been beneath it. Not sure about this but since phone working well, doubt it's significant. Will someone please comment?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
4 respostas
Solução escolhida
I doubt its significant, unless high levels of moisture enters the phone. So, no worries.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Probably not going to cause any issues but yes you put it back on wrong, it goes underneath the battery plug.
https://d3nevzfk7ii3be.cloudfront.net/ig...
Pontuação 4
1 comentário:
Thanks for the prompt response
por
recenty changed my iphone 4s's battrey but afterwords phone keep searching network not able to call is it due to pressure contact or ..?
Pontuação 0
Yes, pressure contact in iPhone 4S is must to suppress RF interferences. It will work as antenna system with the stainless sheet fixed to the cover & in contact with it.
Pontuação 0
Adicionar a sua resposta
PRLevine será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 486
