Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2201 Perguntas Visualizar todos
New screen / glass, touch not working 100%.
Good Day All,
I had ordered a new front glass replacement which came with the LCD and digitizer etc, I got this on my phone without any issues, the screen works 100%, however, the touch screen doesn't appear to be functioning 100%.
I opened the notes app and tried typing each letter of the alphabet, I had difficulty tapping on "H" and "N" and could not hit at all "J" and "U". If you look at the keyboard these keys are all in the same vicinity from top to bottom on the screen. I am wondering if I maybe didn't put down the cable all the way on the motherboard? Or if I got a bad screen?
Thanks!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
Either is a possibility. Easy enough to simply make sure the digitizer cable, closest to camera of the two screen flex connectors, is perfectly in place. If the digitizer is faulty, then when you replace the screen again with a new one, be very careful with the digitizer flex, as it is very vulnerable to damage during installation.
Esta resposta foi útil?
Pontuação 1
buy original screens for replacement, there is a lot of crap screens floating around out there. here is a info graphic on how to tell the difference.
http://www.syncedrepairs.co.nz/blog/orig...
fixit sell good quality. avoid eBay.
Pontuação 1
Phone screen crack
You can send me trick
Pontuação 0
Adicionar a sua resposta
Darren Peck será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 135
