Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2201 Perguntas Visualizar todos
Small component broken from the logic board
Some of the small components of the logic board of an iPhone 4S are gone. It gives problems during charging. They are pointed with an arrow on the picture. What are those? Can I solve this problem by bridge the contact points? Thanks in advance.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Gauthier Top, I marked the components in numerical order. They are a follows.
1. C293 100PF 5% 16 V NP0-C0G Capacitor
2. R153 0.00 0% 1/32W Resistor
part of BATTERY_NTC circuit
3. R61 0.00 0% 1/32W Resistor
4. C300 100PF 5% 16 V NP0-C0G Capacitor
part of BATTERY_SWI circuit
You should get away by bridging the resistors, but I would not bridge the caps. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 4
5 comentários:
It worked. Thank you very much!
por
you are welcome. Thanks for accepting my answer.
por
where can i get those Capacitor and Resistor
por
@Rahul BJ, depends on where you are located. Mouser.com Digikey.com and many other places should have those.
por
Yes they are. The 0 value resistors are actually just jumpers.
por
Adicionar a sua resposta
Gauthier será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 7,593
