Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2201 Perguntas Visualizar todos
Screen colors all messed up after dropping it
I was unfortunetaly very clumsy today and dropped my Iphone 4S. Even though it had a thick case on the top right corner got a scratch and now the screen shows messed up colors. At first it was all white and I could only see the date at the top. Now I can kinda use it but it's hard to see well and a part of the screen doesn't show at the right bottom. The screen isn't shattered so I'm guessing it's a more internal problem, right? I don't know what to do as it's a phone I bought at Apple store in Canada and I now live in Thailand where there is no official Apple store. I'm still under a regular 1 year warranty. Can somebody advise me what to do? I'm very worried and don't have any friends with IT knowledge here...
Thanks,
Isabel
Esta é uma boa pergunta?
Pontuação 12
3 comentários
Karen Turner
por
Someone please answer this question. I have the same problem.
por
I have the same problem! I can't even paint!
por
Adicionar um comentário
4 respostas
Solução escolhida
You could try to follow THIS guide to Step 16 and check if all the connectors are connected.
But I think most probably the LCD is broken and you need to replace it.
Esta resposta foi útil?
Pontuação 2
5 comentários:
the same thing happened to me. someone bumped into me and my phone fell out of my pocket. you have to go to apple to get it repaired. there going to take off your glass screen and they will replace you bottom screen with another so you don't see the lines on your phone (whatever color they are).
por
how much would this repair cost if I were to go to apple for this same type of damage?
por
my iPhone's screen was cracked a little but then it accidentally fell out of my pocket and the button to turn on the iPhone came off,I put it back on and turned it on and my screen was all mest up,is there anyway I can fix it besides going to apple,can I buy a screen and just replace it,are they expensive p?
por
My phone dropped on the floor and my screen is like a totally different color
por
idk what type of iphone I have but magenta lines EVERYWHERE my iPhone also stoped working :( thank you I also can't use it NOTHING will work
por
Same thing happened to my 4... What happened is that wherever it broke, the 'injury' is scrambling the screen's color information. If I lock and unlock my phone, sometimes it shows completely scrambled except for the top status bar, and sometimes only the color is scrambled...
Anyway repair is really the only way to fix it, unless you come up with a workaround. I've enabled the settings that blind people use, so my phone reads to me everything I click, but I don't really need it as sometimes my phone does show up everything just in the wrong color. I know this was posted quite a while ago.
Pontuação 2
1 comentário:
Help I dropped my iPhone and the top left corner of the screen the screen colour is black and all sorts of colours HELP‼️‼️‼️‼️
por
This really helped me after I dropped my phone. There were hues of colours on the screen. I went to settings > general> Accessibility > display Accomodation > and then changed the grey setting to ON and then switched it off again. It done the trick and the screen more or less has gone back to normal just a very slight colour change still exists in the corner
Pontuação 0
I just dropped my IPhone 6s and the colours are all messed up in the bottom, like a virus my phone was already smashed a little but now it’s just unusable in the bottom right of the screen
Pontuação 0
Adicionar a sua resposta
Isabel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 25
Últimos 30 dias: 110
Duração total: 135,889
