Wiki contribuído por estudante
Uma equipe incrível de estudantes do nosso programa de educação fez esta wiki.
Uniden Cordless Phone Troubleshooting Guide D3097S
Uniden Digital Answering System with Caller Announce (D30975)
The Dock Won't Turn On
No matter what you do, you can't get your Phone Dock to turn on.
Before Continuing Your Research First Check That...
- all cables are plugged in securely.
- you press the on/off button, once, allowing a few seconds for start-up.
Damaged/Bad Motherboard
If there is 'absolutely' no response from your dock the motherboard is the issue.
'Absolutely' means there is no response from the dock's speakers, display, light, or charging station.
To fix this issue a new motherboard must be ordered and re-installed.
Check your warranty information in the paperwork included with the device.
My Handset Won't Stay On
No matter what you do, you can't get your Handset to Stay on.
- the dock is turned on.
- the battery pack is inserted properly into the remote and charging station.
Drained/Bad Battery
If your remote exhibits any one of these symptoms:
- Charging but not turning on
- Turning on, but for a short period of time
- Unable to hold a charge
Then it is time for a new set of batteries.
Check your warranty information in the paperwork included with the device. If your warranty has expired the proper batteries can be purchased at many stores.
3 comentários
Why am I getting a beep every now and then.
richsmiles@juno.com
Richard Miles - Responder
How can I get rid of the beep?
My phone says “Silent Mode On". How do I turn this off?
Lisa Brown-Joseph - Responder
