Wiki contribuído por estudante
Uma equipe incrível de estudantes do nosso programa de educação fez esta wiki.
If your TOGUARD C310 Dual Dash Cam doesn't last long on a single charge, follow this troubleshooting guide for possible solutions.
Using a 3rd party charging adapter
- The battery might be damaged if you have used 3rd party charging adapter. If it has a higher voltage output than the battery allows, it might have damaged the battery. Use a charging adapter with the same voltage as the battery.
Micro USB and Charging Port Are Dirty
- There may be debris obstructing the charger and/or the charging port to make contact. Make sure that there isn't debris by cleaning them. For details on cleaning a charging port safely, refer to this guide.
Battery Is Dead
- The battery is no longer holding a sufficient charge because it has reached the end of its limited charging cycles. Replace the old battery with a new one.
0 comentários
