Powerbook won't turn on
Your computer will not boot.
Bad DC & sound card
If your DC & sound card is bad, you will not be able to start your computer when it's plugged into the wall. It may or may not run on battery and the light on the power adapter will not light up at all (some power adapters do not have lights, so this may not apply to your computer). These symptoms point to a DC & sound card that needs to be replaced (1.0-1.5 GHz (BT 1.1) or 1.5 (BT 2.0)-1.67 GHz (LR)).
We carry replacements for the following DC & sound card: 1.0/1.25 GHz, 1.33/1.5 GHz (BT 1.1), 1.5 (BT 2.0)/1.67 GHz (LR), and 1.67 GHz (HR).
Bad power adapter
If your power adapter is bad, the computer will run off a battery, but it won't charge. If your battery's charge is too low, it will be difficult to diagnose a bad power adapter. The easiest way to test this is to borrow either a battery or power adapter to test in your machine. If you have the same problem with another power adapter, your problem is most likely the DC & sound card. If you have the same problem with a fully charged battery, you most likely need a new logic board. For your reference: Aluminum 15" requires a 65-watt adapter in order to boot. A 45-watt adapter will not provide sufficient power to run your machine. Compatible power adapters are IF113-018 and IF113-039.
Bad logic board
If replacing the DC & sound card and battery doesn't fix your problem, replace (1.0-1.5 GHz (BT 1.1) or 1.5 (BT 2.0)-1.67 GHz (LR)) the logic board.
Laptop shuts off when I unplug it
As soon as you unplug the computer from a power source, it shuts off
Dead battery
If your battery is dead, the computer will run fine off the power adapter, but will turn off when unplugged. A dead battery can manifest itself in many forms: It may not accept a charge (this particular symptom may also indicate a problem with the logic board), the computer may not recognize the battery, or the battery may be recognized as charged but fail to power your computer when the AC adapter is unplugged. We sell new and used batteries.
Flashing question mark on startup
The computer displays the flashing question mark when it can't find a bootable operating system. This could be because your OS is corrupt, the computer doesn't have enough RAM, or your hard drive is failing.
Bad operating system
Try booting off an OS CD. Run Apple's Disk Utility and try to repair the disk. You could also try Alsoft's DiskWarrior. If this fails, reinstall your operating system. If you can, erase the hard drive prior to reinstalling the OS.
Not enough RAM
This is quite rare. If you have insufficient RAM for your computer to boot the operating system, you may get the flashing question mark. Installing (1.0-1.5 GHz (BT 1.1) or 1.5 (BT 2.0)-1.67 GHz (LR)) more RAM or downgrading to an older operating system will fix this. This is not usually an issue unless you have 64 MB or less RAM and you're running OS X.
Bad hard drive
The hard drive may have been erased, corrupted, or damaged. If the hard drive has been erased, format it as HFS+ and reinstall your operating system back onto it. If it is corrupted or damaged, you need to replace it. Failing hard drives can display intermittent data corruption prior to failing completely. They often gradually get louder and start to click. If your hard drive is making abnormal clicking noises but still works, back up your data immediately and replace the hard drive. Any of our 9.5mm ATA hard drives will work in your computer.
My screen looks black, but I can see very faint graphics on it
Symptoms of this are a dark screen, but everything else seems to be running. If you get in close with a flashlight, you can usually see the image faintly.
Backlight
If your backlight isn't working, the inverter may be bad. Other parts that may be bad are the display or the logic board. If your backlight fails intermittently while moving the display, the problem is with the [/search/15+alu+inverter+cable+antenna|inverter cables]. Otherwise it is impossible to test for damaged parts without replacing them one by one. If you are comfortable taking apart the display assembly, replace the display inverter first, then replace the LCD. If you are not comfortable with this, you can replace both parts at once by replacing the [/search/15+alu+display+assembly+LCD+bluetooth|display assembly] (which contains both components). If this still doesn't solve your problem, you need a new logic board.
Other problems
Ports/Audio
If you lose firewire or ethernet, the only thing to blame is the logic board. Because there are many components of the logic board, many possible symptoms indicate logic board failure. Any one of these components can fail and leave the others intact. If you lose audio or USB on the left side of the machine, the DC & sound card is to blame and must be replaced (see above). Loss of USB on the right side requires the replacement (1.0-1.5 GHz (BT 1.1) or 1.5 (BT 2.0)-1.67 GHz (LR)) of the [/search/15+right+usb+port|right USB board]. If you lose the use of another component of your computer, such as the display, battery, or even power, and replacing the apparently non-working part didn't fix the problem, it is possible that the logic board may need to be replaced (see above).
6 comentários
HI I HAVE A G4 POWERBOOK WITH 2GB O RAM AN 80 HARDRIVE AND MY PROBLES IS EVERYTIME I TURN ON MY LAPTOP LOAD UNTIL I PUT MY PASSWORD AND THERES NO WALLPAPERS OR ANYTHING I WANNA KNOW WHAT'S GOIN ON ? PLEASE SOMEBODY EMAIL ME AT GAMALIERMARIN@YAHOO.COM THANKS FOR THIS NICE SITE
gamaliermarin - Responder
If you'd like replies to your comments go to Answers!
originalmachead - Responder
I have apple macbook pro model 1046 . When I turn on it starts up fine but after 10 minutes the screen begins to breakdown and the screen looks like it has cancer.
Jeff - Responder
This is not the DIY help Question and Answer Forum. Go here start your own Question. From your description it's either the GPU (Video Chip) or your display going bad. Connect to an external monitor and if you see the same thing after the same amount of time it is the GPU. If not it is most likely the on-board display.
originalmachead -
I have a Powerbook G4. I cannot get anything on the screen. I press the power button and it sounds like it is coming on, but nothing on the screen. It makes a hum and then a beep beep beep, but nothing on the screen. I've tried pressing the brightness button, but no change. Are there other things I can try before taking it to someone to repair.
wraydance - Responder
