Wiki contribuído por estudante
Uma equipe incrível de estudantes do nosso programa de educação fez esta wiki.
Common PS Vita Slim Problems
Diagnose and fix the most common problems plaguing your PlayStation Vita Slim handheld console with these step-by-step DIY troubleshooting guides.
4 Solutions | PS Vita Slim Not Charging |
The device refuses to charge despite being plugged in. Potential causes include software not functioning, hardware not registering charger, improper charger connection, faulty AC charger, and software error. | |
2 Solutions | PS Vita Slim Cannot Connect to WiFi |
The user is having trouble getting the device to sync to any WiFi source. Potential causes include a blocked system access point, a need to reconnect, DNS error causing the device to not find the router, device failing to find the router, and a software error introduced in an update. | |
2 Solutions | PS Vita Slim Unresponsive Joysticks or Buttons |
The device is not responding to any inputs, and the joysticks cannot be used. Potential causes include sticky and dirty buttons or a broken joystick. | |
1 Solution | PS Vita Slim System Can’t Find Memory Card |
The system regularly fails to access the memory card. Potential causes include a memory card that was bumped out of place. | |
2 Solution | PS Vita Slim Unresponsive Black Screen |
The device displays a black screen and refuses to show any active inputs. Potential causes include a dead battery, or a system glitch. |
Didn't find your problem?
Check out the Answers forum if you need more troubleshooting help for your specific issue. Maybe someone has already solved the same issue you are experiencing.
8 comentários
Hi My Vita is dead in the water tried everything there is no sound and touch screen not working and screen is dead but i can switch the vita on and off but doesn’t want to do anything else.Help please!!!
Ruan Dirker - Responder
sounds like a softbrick, which cannot be undone at this time. sorry for your loss pal :(
Owen Davies -
my vita power on and display the playsation logo then it turn off
saligaM - Responder
Why when playing baseball , the defense players dive toward the ball instead of running…what would cause this and flickering the teams, schedules. It’s doing it on its own, very aggravating.
franbhorne - Responder
Hi, my son dropped his Ps vita into water and I did dry immediately. Then it won’t turn on. I opened it and used charger to connect , the indicator is orange . I pressed the power button , and turned on when connected charger. I charged for battery for a hour. But it won’t turn on when I disconnected the charger. Is there any problem or damage for motherboard or ?? Please give me the advise or any idea ? Thank you
Johnson - Responder
