Does your Lenovo IdeaPad U530 Touch laptop have distorted audio? Lenovo IdeaPad U530 Touch laptop computers are susceptible to a range of problems that could cause audio distortion. Check the following possible causes to identify and solve the problem.
Malfunctioning Audio Driver
If your laptop’s audio works but is distorted, there might be a problem with the computer’s audio drivers. Test the audio through the computer speakers, then test it using headphones. If the laptop cannot recognize the headphones when they are plugged in, you will need to reinstall your audio driver.
Damaged Headphone Port
If the audio is distorted while listening on the headphones, the audio jack or the headphones may be broken. If this is the case, you may need to replace the audio jack. Insert a different pair of headphones and see if the audio issues go away or try the same headphones with a different device.
Damaged or Dirty Speaker
If the audio comes through the headphones loud and clear but the audio coming through the speakers is distorted then it is possible the speaker is damaged and needs to be replaced.
0 comentários
