Wiki contribuído por estudante
Uma equipe incrível de estudantes do nosso programa de educação fez esta wiki.
Short-term Battery Life
The laptop shuts down frequently and dies soon.
Charging-port Issues
It is possible that the cord could be loose or that the port itself has a lot of dirt or debris in it that clogs it. If your computer is charging very slowly this could be a cause. Check to see if the ports have been tightly secured to ensure proper charging. Presuming that is not the case, it may be because dirt/debris has found its way inside the port, the best way to fix this is by getting a can of compressed air and spraying at the area.
Outdated Software
Battery drainage challenges may be linked to outdated software. When utilizing Lenovo Vantage, you may look for updates.
Check which processes are consuming the most energy by accessing the Task Manager in Windows (right-click the taskbar and choose Task Manager). You can try powering down or wiping any resource-hungry apps you notice running.
Sluggish performance and Slow Boot Time
The laptop runs slow and contains weak boot times.
Start up apps
By turning off the majority of starting apps, you can speed up Windows boot time. Starting apps can slow down Windows boot time. Use this link to see ways to do this for your operating system.
Close extra browser tabs
Delete any unused browser tabs. Your computer may get sluggish if you open too many tabs. This is the simplest solution but can go a long way for your system to run better.
Slow Hard Drive
The laptop contains a hard drive performance reduction.
Free Up Space
Your Lenovo laptop will lag if your hard drive or system drive is nearing its capacity. By emptying up disk space or increasing the C drive, users can check for limited disk space on their computer and enhance pace. Microsoft has tips on how to free up drive space on your PC, just click on this link.
Upgrade to SSD
Compared to a traditional HDD, an SSD has access speeds of 35 to 100 microseconds. A solution that offers to enhance your Lenovo's performance and solve the running sluggish issue by swapping out the rotating hard drive for a new SSD. Search online for compatible SSDs that can run on your system.
Software Crashes
The laptop crashes constantly.
Corrupted Files
Incorrect file saving may cause a file to corrupt. Any file that was being transferred at the time may become corrupted if a file relocation procedure is incorrectly halted. When you unplug storage devices from the computer without removing them carefully, the data may also become corrupted. Microsoft support has a way to prevent this from happening in the future. Check out this link to learn more
Free up Disk Space on C Drive
Your C disc will continue to freeze if it is full because it is where the system files are stored. Remove desktop applications you no longer use. To access Programs and Features, click Start, Control Panel, Programs, and then Programs and Features. Click Uninstall after selecting a program.
Black Screen
The laptop screen will not turn on and/or not display correctly.
Reset the Display or Screen Mode
The loss of connection between the screen display and the Windows operating system is one of the causes of the black screen problem in Lenovo laptops. Resetting your laptop's display mode will quickly fix the issue. Simply hit Windows () + Ctrl + Shift + B to complete the task. If that does not work, try this link from Microsoft Support on how they troubleshoot black or blank screens on Windows.
Faulty Laptop Battery
Your Lenovo Ideapad's black screen may possibly be caused by a defective battery. If your laptop abruptly shuts down, unplug the charger from the battery source to determine if the problem is with the battery. To make sure, try switching out your battery with a functional one. You can check out part, of this model, from iFixit on this link.
0 comentários
