Wiki contribuído por estudante
Uma equipe incrível de estudantes do nosso programa de educação fez esta wiki.
Troubleshooting
Device will not power on
" The device will not show any sign or response. This problem is mainly occurs because of two reasons:''
Dead battery
If this is the problem, you will need to replace the dead batteries with one ones.
On/Off power switch is broken/not working
''If the you replace the batteries and the problem continues, then it is most likely that the On/Off switch is broken or not working properly. Then you will need to replace the switch"
Very small coverage area
" This problem occurs when you start loosing the coverage which results in miscommunication. The common causes are:''
Distance
If you or your partner leave the 2 miles range, you will start loosing the coverage.
Antenna
Another reason of loosing the coverage is Antenna. If you are within the 2 mile range and there is not enough coverage, then this might be a problem with the Antenna. Try to replace the Antenna to get better coverage.
Press-to-speak button
Sometimes the problem is because the press-to-speak button. Try to replace it and see if this problem is gone.
Too much static noise from the speakers
" When you are using the device, you would start hearing static noise coming out of the speaker. This problem commonly happen because of two reasons''
Interference with radios
The only way to get red of the noise if there is interference with radios, you must change the channel to another one.
Speaker
If you hear noise and you know that there is no interference with radios, the problem is most likely is from the speaker. Replace the speaker and check if the problem is gone.
For more information regarding common troubleshooting issues, please visit [Common Issues]
0 comentários
