Wiki contribuído por estudante
Uma equipe incrível de estudantes do nosso programa de educação fez esta wiki.
Will Not Connect To Internet
The Insignia TV will not connect to an Internet network.
Internet Provider Failure
If your Insignia TV will not connect to the internet, your internet provider service could be the problem. Check your internet connectivity by connecting another device to your internet. If your other device fails to connect, contact your internet providers to check for outages in your area. Consider switching to a more reliable provider.
Restrictive Wifi Settings
If your Insignia TV will not connect to the internet, it may be because your home wifi settings are restricting access to it. The Insignia TV requires a lot of data in order to stream channels and your Wifi may not support this need. Try adjusting your Wifi settings to allow more data to be used. Consider upgrading to unlimited data. You can also plug the computer directly into an ethernet source, by using one of the USB ports on the back of the tv, and a USB to ethernet converter.
Picture Does Not Appear
Audio is on but picture is not visible.
Requires Part Replacement
If the screen is black but you can still hear the audio, try shining a bright light on the screen. If no image can be seen, there could be two things that might need to be replaced: either the lamp or the Light Sensor.
Lighting Element in Screen Has Gone Out
If the screen is black but you can still hear the audio, try shining a bright light on the screen. If an image can be seen, the lighting element in the screen has gone out. Since Insignia Televisions are a self contained unit and most small parts cannot be replaced, this problem would require the entire screen to be replaced. Replacing your television, however, would be less expensive than replacing just the screen.
Picture Will Not Fit Screen
Picture is either too big or too small for screen.
Settings Issue
It is likely that the picture will not fit your screen due to an issue in your settings. To resolve this, press the star button on the Roku remote and scroll to picture size using the up and down arrows. Select picture size and then choose a new size. Choose a larger size if the picture is too small. Choose a smaller size if the picture is too large.
Has Power, But Will Not Turn On
Insignia TV is plugged in, but no image appears.
Power Reset
If your Insignia TV will not turn on, you can try a power reset. To perform a power reset, unplug the set from the outlet. Then proceed to hold down the power button for one minute. Release the power button, plug the TV back into the outlet, and attempt to power on. If the TV turns on, it is likely that a power supply replacement may become necessary in the near future. If the TV does not turn on, the issue is with either the power supply or a fault on the motherboard itself.
No Signal With HDMI 1 or 2
Your TV will not display HDMI video.
HDMI Reset Needed
To do an HDMI reset, unplug both the TV and all other connected devices. Then, disconnect all of the HDMI cables from both ends and reconnect them. Lastly, plug in all of the connected devices to the power. Give them about 30 seconds to boot up before plugging in the TV.
Video is Distorted on HDMI
Video image is distorted, blurry, or discolored when plugged into a computer with HDMI.
Incorrect Resolution
The computer may be operating in an incorrect resolution. To fix this, double check the Resolution settings by right-clicking the desktop, and selecting “Screen Resolution.” The ideal resolution for every computer is different. To change the resolution settings of your computer display, go to settings, display, advanced display settings (if you cannot currently see a setting for the resolution) and change the resolution to best fit the TV. Play around with different resolution settings, until you find the one that looks the best on your TV.
109 comentários
Try to turn r 46in insignia tv on red light blinks 5 or 6 times and screen flashes on and then tv go right off
Larry Dean Anglin - Responder
I need help i got a insignia LED tv model # insignia tv ns-42d510na15 and well it won’t turn on ! If I plug it in the red light come on and blinks only one time then nothing !! No picture,no sounds, nothing at all ! I lost the remote control and apparently this tv model doesn’t have menu or on and off bottom I can’t find them ! It had some like stickers saying power ,menu, input,volume but not %#*@ bottoms for it ! What do do ? Does anymore know ! Pls help
G. Michael Coss -
Turn on the TV and the red light flashes 9 times. TV comes on and Asks me for the input. I choose HDMI and then it asks for the language and freezes. It’s on English, which is what I want but the ENTER button does nothing….and I can’t proceed any further.
Tom Fischerkeller - Responder
What should you do when your remote enter button stuck on English won't proceed
RON ADAMS -
I Do a power test but nothing worked… nothing is wrong with the power OR motherboard… What do I do?
Theron McCauley - Responder
