Wiki contribuído por estudante
Uma equipe incrível de estudantes do nosso programa de educação fez esta wiki.
Computer Will Not Power On
The laptop will not respond or show any sign of powering up
Faulty Power Adapter
Check to make sure the power adapter is plugged in. If it is, make sure the light on the adapter is on. If the light is not on, and the adapter is plugged in, then the adapter may be faulty. Consider purchasing a replacement adapter.
Faulty Battery
Unplug the power cord and remove the battery from the back of laptop. Then hold the power button for 60 seconds. After connecting to a power supply, try to switch on the laptop. Finally put the battery back into the laptop.
Black Screen When Computer is On
The laptop is powered on but the monitor does not display anything
Faulty/Damaged LCD
Attach the laptop to an external monitor. If the external monitor comes on, there might be something wrong with your LCD. Could be the cable, the inverter or the LCD panel itself.
Damaged Motherboard
Attach the laptop to an external monitor. If the external monitor does not come on, you are having issues with your video card, which is an integrated part of your motherboard. You can use this guide to replace your motherboard.
Caps Lock Failure
Caps lock button does not respond when pressing it
Faulty Keyboard
If the entire keyboard fails to respond, try replacing it with this guide.
Other Components
Numerous components need to check including battery, power adapter, CPU, memory, system board, depending on how many blinks the caps lock blink.
Windows Programs are not Opening
The laptop is turn on but windows is not running
Faulty Drivers
Check for updates for the drivers or reinstall drivers on laptop. Using the systems restore setting can revert the drivers back to the previous state.
Laptop Will Not Connect to a Wireless Device
Laptop does not connect to any wireless device while it is on
Chipset Driver
Make sure your wireless is On, download and reinstall the Chipset driver with this link here. After that restart your laptop and see if it works.
1 comentário
My Compaq Presario CQ62 screen is blank. The F12 key is red and the Caps lock key is blinking
chez_leo - Responder
