Wiki contribuído por estudante
Uma equipe incrível de estudantes do nosso programa de educação fez esta wiki.
Acer Aspire One Cloudbook 14 AO1‑431‑C8G8 Troubleshooting
This troubleshooting page will help identify problems with the Acer Aspire One Cloudbook 14
Audio Does Not Work or is Distorted
There is little or no sound when attempting to play audio through the computer speakers.
Broken Speakers
First you must test the audio through the headphone jack. If the sound is still distorted through the headphone jack, see next section on a driver error. If the audio is clear through headphones, then it is not a software issue and is only caused by the speakers themselves. Follow this guide (link to speaker repair guide) to replace your computer speakers.
Driver Error
If the audio is distorted through the computer speakers and the headphone jack, the audio drivers will likely need to be updated. To do this, search for Acer Aspire Cloudbook 14 Audio Drivers. Navigate to Acer’s website and enter your serial number, SNID, model number or select your device from the dropdown menu. Select Driver from the menu and select the download from the Audio Driver section. Next, navigate to Device Manager in settings on your computer. Select Audio inputs and outputs and open Speakers. Select the driver tab, click update driver, and navigate to the driver you previously downloaded. After this process is complete, restart your computer.
Black Display
The display will not turn on or produce any images when powering on your device.
Incorrect Display settings
First, you may want to check if your computer is set to a different display mode that would cause the screen to remain black. To do this, press the windows key and P key twice to switch in between project mode. If this does not work, the display is in the correct mode and the screen is faulty. Refer to the next section.
Faulty Screen
If the above commands did not work, you will need to replace the display. Simply follow
the repair guide to replacing the screen on your Acer Aspire One Cloudbook 14 here. (link to repair guide)
The USB Port Does Not Recognize Devices
The Acer laptop does not recognize anything that you plug into it.
Restart Your Laptop
Before you begin to take apart your laptop, turn it off and back on. This will restart everything running on the laptop. After that, check if your USB port is responsive again.
Faulty USB Wire
If you have restarted your computer and the USB port is still unresponsive. Try to connect a different device. The issue may lie with the device you are trying to connect. If that is the case, look into replacing the USB wire you are using.
Faulty USB Port
Your USB port may have come loose or burnt out. You might have to open the back of the laptop and replace the USB port manually using this guide.
Laptop Will Not Hold A Charge
The Acer laptop’s battery discharges quickly.
Faulty Battery Connection
Before taking out and ordering a new battery, check to see if the battery is securely connected to the motherboard and charging port. Check out this guide for taking apart the laptop.
Faulty Battery
If the laptop functions fine with the charger cable plugged in, the issue may lie with the laptop’s battery. Check out this guide to find out how to replace the Acer laptop’s battery.
Unresponsive Touchpad
The touchpad will not respond at all.
Outdated Driver
Make sure that the touchpad is not locked (FN+F7). If still not working then check to see that the driver is up to date.
Faulty Touchpad
Driver is updated and touchpad is not locked but still does not work. Next step is to replace the touchpad.
0 comentários
