Wiki contribuído por estudante
Uma equipe incrível de estudantes do nosso programa de educação fez esta wiki.
Wings are gentle
Wings maybe get broken easily during a crash landing or any other event. It scenario like this the propeller are usually easy to remove and replace with another set.
Battery will not stay in place
-The battery does not stay in place, causes a malfunction when take off and charging.
The common symptom would be that the battery holder is too loose or the battery shape is broken. If the battery is not charging that means that the battery needs new battery that's easy.
Wires are cut off
In cases where wires are attached, best thing to do would be to try to place in back into it spot with a clippers, these wires are very thin and test if it works. Put the wires back in it place and glue it with hot glue.
Motor
On account of the motor issue, the propeller won’t spin because it the power applied by the motor so as to turn. Make sure the motor is working fine because most of the energy goes into the propellers.
Camera is not clear
- Blurry
- If the camera is blurry try to clean the lens of the camera or try to replace the lens it should be working fine. Also, try to change the camera adjustment to see if it will work better and double-check if the wire is connected to the camera.
Wings are gentle Wings maybe get broken easily during a crash landing or any other event. It scenario like this the propeller are usually easy to remove and replace with another set. Battery will not stay in place -The battery does not stay in place, causes a malfunction when take off and charging. The common symptom would be that the battery holder is too loose or the battery shape is broken. If the battery is not charging that means that the battery needs new battery that's easy. Wires are cut off In cases where wires are attached, best thing to do would be to try to place in back into it spot with a clippers, these wires are very thin and test if it works. Put the wires back in it place and glue it with hot glue. Motor On account of the motor issue, the propeller won’t spin because it the power applied by the motor so as to turn. Make sure the motor is working fine because most of the energy goes into the propellers. Camera is not clear Blurry If the camera is blurry try to clean the lens of the camera or try to replace the lens it should be working fine. Also, try to change the camera adjustment to see if it will work better and double-check if the wire is connected to the camera.
2 comentários
Salam
I need propeller of parrot bebop 2 drone,
Hoi fo for that
AHMAD TARIQ Lahore Pakistan
Ahmad Tariq - Responder
my drone will not turn on at all, ive tested the batteries they are perfectly fine. but it wont even let me turn it on any help here would be greatly appreciated.
jdizzel21 - Responder
