Ir para o conteúdo principal
Constructing a Capacitor Discharge Tool
O que você precisa
  1. Constructing a Capacitor Discharge Tool, Constructing a Capacitor Discharge Tool: passo 1, imagem 1 %32
    • To construct a capacitor discharge tool, first gather the necessary materials. These include:
    • Two lengths of wire. Minimum wire requirements is 12AWG, 600 volt rating for large electrolytic capacitors used in power supplies, electric motor start circuits and camera flash circuitry
    • A resistor rated to dissipate the amount of thermal energy created when discharging the capacitor. Minimum requirements for resistor is 2k OHM 5w for small capacitors, 20k OHM 5w for large electrolytic capacitors used in power supplies, electric motor start circuits and camera flash circuitry.
    • Shrink tubing
  2. Constructing a Capacitor Discharge Tool: passo 2, imagem 1 %32 Constructing a Capacitor Discharge Tool: passo 2, imagem 2 %32
    • Begin the process by stripping one side end of each length of wire.
    • To ensure a solid solder joint, strip at least .25" of insulation off the wire.
  3. Constructing a Capacitor Discharge Tool: passo 3, imagem 1 %32 Constructing a Capacitor Discharge Tool: passo 3, imagem 2 %32
    • Next, trim both of the leads leaving the resistor to match the length of insulation stripped off the wires in the previous step.
  4. Constructing a Capacitor Discharge Tool: passo 4, imagem 1 %32 Constructing a Capacitor Discharge Tool: passo 4, imagem 2 %32 Constructing a Capacitor Discharge Tool: passo 4, imagem 3 %32
    • Join the lead leaving the resistor to the stripped end of the wire by twisting the two together.
    • The wire we are using is quite thick, so we inserted the resistor lead down the center of the conductor portion of the wire and twisted the wire against it as tightly as possible.
    • Solder the wire to the resistor.
    • It is essential that enough solder flows through the wire to create a permanent bond between the two pieces.
  5. Constructing a Capacitor Discharge Tool: passo 5, imagem 1 %32 Constructing a Capacitor Discharge Tool: passo 5, imagem 2 %32
    • Slide a section of shrink tubing up the wire, making sure to completely cover up the solder joint and any exposed wire.
    • Use a heat gun or lighter to shrink the tubing over the joint, making sure it is positioned to cover all exposed wire.
  6. Constructing a Capacitor Discharge Tool: passo 6, imagem 1 %32
    • Repeat the above process for the other side of the resistor.
    • To complete the discharge tool, strip the ends of the wires.
    • To discharge from small points, it may be helpful to cut the exposed ends of wire into a point shape and solder them to maintain the shape. Alternatively, the probes commonly used on multimeters can be soldered to the wires to create a more precise discharge tool.
    • For large electrolytic capacitors used in power supplies, electric motor start circuits, and camera flash units, you may want to solder one end to a large alligator clip and the other to a well insulated screwdriver.
Linha de Chegada
135 outras pessoas executaram este guia.
11 comentários
This article is by far the best I've read. I have made these in the past and had to get past the amount of words used to describe what needed to be done with what. This article is straight to the point and the tips ( using alligator clip ) are excellent.
Paul Kriner - Responder
I get the basics and can build something more to fit my needs, with what you have instructed
puckhead22 - Responder
hi
i have one query, if it is possible to discharge the capacitor in 12V 1 A power supply..? if i cut of the power, the power supply discharge the power around 6 sec but i need to discharge it with in 1 sec ..? this is possible or Not...?
prakashkumar - Responder
Thank you! I have been looking for a good diy discharge probe....I also used overlapping large size heat shrink to strengthen the joint at the ceramic resistor to prevent failure at a bad time.
doorabull2 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 40
Últimos 7 dias: 356
Últimos 30 dias: 1,704
Duração total: 211,303
