Introdução
Get to that gross area in that back of your countertop ice maker for cleaning.
O que você precisa
Remember that ice makers contain toxic refrigerant. Hand and eye protection are recommended
A medium phillips-head screwdriver is also required
unplug your countertop ice maker
place over the sink and pull out the rubber stopper from the bottom
wait for all fluid to drain
Once drained, place ice maker on its side. Remove the highlighted screws that hold the back plastic cover in place.
Then remove the black plastic cover.
remove the screws holding the top cover in place.
Don't forget the other side!
remove two screws holding the tray motor in place. Then pull the tray motor straight out. It may require a bit of force if rust is sticking it onto the tray
remove the water intake hose by pulling it straight down
uncover the electronics by unclipping the specified points
unplug the wire connecting to the right side panel
remove the screws holding the side panels in-place
unscrew the refrigerant pipes from the side panel
carefully remove both side panels
at this point, the ice tray should be freed up for removal (and cleaning)
