Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua iPod Shuffle 1st Generation, use o nosso manual de serviço.
  1. iPod Shuffle 1st Generation Teardown, Hold Switch: passo 1, imagem 1 %32
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    Pergunte ao FixBot
    Comentar
  2. iPod Shuffle 1st Generation Teardown: passo 2, imagem 1 %32
    • Use a spudger to pry up the white plastic hold switch.
    Pergunte ao FixBot
    Comentar
  3. iPod Shuffle 1st Generation Teardown, Casing: passo 3, imagem 1 %32
    • If present, remove the cap from the USB port.
    Pergunte ao FixBot
    Comentar
  4. iPod Shuffle 1st Generation Teardown: passo 4, imagem 1 %32
    • The following step can be challenging and time consuming. Be sure to go slowly and have patience to prevent damaging your iPod.
    • Use an Exacto knife to separate the glue holding the USB port on the iPod. Run the knife along the seam between the two sections of the iPod until the glue is separated. Expect to run the knife along this edge 20-30 times before the glue will be entirely freed.
    Pergunte ao FixBot
    Comentar
  5. iPod Shuffle 1st Generation Teardown: passo 5, imagem 1 %32
    • Continue to run the knife around all four edges of the USB port until the glue is released. You may be able to gently wiggle the knife from side to side to help release the glue.
    Pergunte ao FixBot
    Comentar
  6. iPod Shuffle 1st Generation Teardown: passo 6, imagem 1 %32
    • Use a spudger to push on the headphone jack and slide the USB port out of its housing.
    • If the USB port doesn't come free, check to make sure all the glue holding the USB port in place has been released. Pulling on the USB port itself is not recommended as there is a fragile ribbon cable that can be ripped if the USB port suddenly comes free.
    Pergunte ao FixBot
    Comentar
  7. iPod Shuffle 1st Generation Teardown: passo 7, imagem 1 %32
    • After the USB port comes free, carefully slide it out of its housing. Don't pull it out too far because there's still a ribbon cable connecting it to the logic board.
    Pergunte ao FixBot
    Comentar
  8. iPod Shuffle 1st Generation Teardown: passo 8, imagem 1 %32
    • Continue to slide the iPod out of its casing by using a spudger to push on the logic board near the headphone jack.
    Pergunte ao FixBot
    Comentar
  9. iPod Shuffle 1st Generation Teardown: passo 9, imagem 1 %32
    • Turn the iPod so that the click wheel is facing up. This will prevent the battery indicator from falling out.
    • If the battery indicator does fall out, don't forget to replace it prior to reassembling the iPod. Getting the battery indicator back in place can be tricky. You'll have to slide it in from the end of the iPod's casing and get it to fall into its slot in the casing.
    • Slide the iPod out of its casing.
    Pergunte ao FixBot
    Comentar
  10. iPod Shuffle 1st Generation Teardown, USB Port: passo 10, imagem 1 %32
    • Use a spudger to flip up the black plastic tab holding the USB port ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
    Pergunte ao FixBot
    Comentar
  11. iPod Shuffle 1st Generation Teardown: passo 11, imagem 1 %32
    • Carefully peel the yellow USB ribbon up from the battery.
    Pergunte ao FixBot
    Comentar
  12. iPod Shuffle 1st Generation Teardown: passo 12, imagem 1 %32
    • Slide the USB ribbon out of its connector.
    • Lift the USB port and detached ribbon cable out of the iPod.
    Pergunte ao FixBot
    Comentar
  13. iPod Shuffle 1st Generation Teardown, Battery & Logic Board: passo 13, imagem 1 %32
    • Gently pull back the white plastic framework to free the left edge of the logic board. Pull up on the logic board slightly to prevent the logic board from falling back into place.
    Pergunte ao FixBot
    Comentar
  14. iPod Shuffle 1st Generation Teardown: passo 14, imagem 1 %32
    • Repeat the same procedure on the opposite side to free the logic board from the white plastic casing.
    Pergunte ao FixBot
    Comentar
  15. iPod Shuffle 1st Generation Teardown: passo 15, imagem 1 %32
    • Lift the logic board up to disconnect it from the memory board beneath. Don't remove the logic board from the iPod yet, because it's still connected to the battery.
    Pergunte ao FixBot
    Comentar
  16. iPod Shuffle 1st Generation Teardown: passo 16, imagem 1 %32
    • Turn the iPod over and use your finger to push the battery through the hole in the casing. The battery is attached to the plastic framework with a mild adhesive.
    • Lift the battery and logic board out of the iPod.
    Pergunte ao FixBot
    Comentar
  17. iPod Shuffle 1st Generation Teardown, Memory Board: passo 17, imagem 1 %32
    • Peel up the translucent tape securing the memory board to the edge of the white plastic framework. It is only necessary to peel up the tape on one side, as the other side will be freed while removing the memory board.
    Pergunte ao FixBot
    Comentar
  18. iPod Shuffle 1st Generation Teardown: passo 18, imagem 1 %32
    • Lift the memory board out of the framework and peel the tape off the other side of the framework.
    • The white plastic framework is not very strong. Be careful not to exert too much force on the thin plastic arm when peeling off the tape.
    Pergunte ao FixBot
    Comentar
Ashley Ryan
Membro desde: 03/25/12
5.617 Reputação
Autoria de 3 guias
Equipe
Master Techs Membro de Master Techs
Community
333 Membros
Autoria de 1.485 guias
3Comentários do guia
hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm needs more description
Feyrowan - Responder Compartilhar
Great step-by-step instructions! I’ll probably never teardown my iPod, but it’s good to have the instructions!!
Andy Cheng - Responder Compartilhar
the markings on my battery are:
502030
492528
+500092
'502030' is the battery size you want to get.
To take apart my iPod Shuffle, I didn't need a knife, but used isopropyl alcohol in between the seams, then wiggled it for a while. a few small 'cracks' were heard, and then it was loose. your mileage may vary.
CH23 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 31
Últimos 30 dias: 178
Ao todo: 19,784
